Coming from someone in a group chat I know nothing about specs so asking for him can someone answer this please, would the 940n have twice or more the range of my current 740n?
PC Build
Ryzen 1800x
Asus Strix 1080ti
G-Skill Trident z RGB 32gb 3200mhz
Gigabyte K7 motherboard
NZXT Kraken x62
EVGA Supernova P2 850w
Phanteks Enthoo Evolv ATX TG
SAMSUNG 960 EVO M.2 1tb
Seagate Barracuda 3tb
Gigabyte WiFi and Bluetooth Card
x3 NZXT Aer RGB Fans
NZXT Hue
https://linustechtips.com/topic/716279-question-about-wifi/
1 minute ago, harry4742 said:
i dont know which devices you are talking about but probably NO
Tp link routers
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/716279-question-about-wifi/#findComment-9127151
3 minutes ago, Zolfe said:
Tp link routers
look at the specs?
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/716279-question-about-wifi/#findComment-9127161
Generally no. You'd get faster speeds and maybe some additional range depending on the power/signal strength but you probably won't see near double the range.
Current Network Layout:
Current Build Log/PC:
Storage Server Setup:
Prior Build Log/PC:
https://linustechtips.com/topic/716279-question-about-wifi/#findComment-9127164
Yeah, I'm in agreement. There are limits (at least here in the United States) which the FCC has in play for how much power a router can consume for wireless. This is why we don't see ultimate range home wireless routers, where one router can serve an entire mansion. Sure, we have P2P links... but they're broadcasting at a more narrow 30* angle.
Regards,
Remix
Please (@mention) my username. Otherwise I may not see your message!
https://linustechtips.com/topic/716279-question-about-wifi/#findComment-9127191
But its better this way, imagine an appartemnt house with 200 flats, each having their own super range router :D
https://linustechtips.com/topic/716279-question-about-wifi/#findComment-9127200
then how much of an increase will it be? 50% more?
https://linustechtips.com/topic/716279-question-about-wifi/#findComment-9127202
If you can find the antennas, you can do a hack job to make them into directional antennas by making aluminum foil based "dishes". It'll get you more range, but then you severely limit your coverage.
https://linustechtips.com/topic/716279-question-about-wifi/#findComment-9127209
Oh absolutely. The RF environment would be terrible.
There isn't a science to it. There is no doubt that tells me the 940n will provide you with slightly more coverage... not very much, but it will provide you with faster speeds overall with the limitations of 2.4GHz. The 940n to me looks like a slightly upgraded version of the 740n. Reception Sensitivity just looks like you'll achieve faster speeds in the areas where you may have not before. They still have the same Transmit Power, so something tells me you won't see a huge range improvement. Probably not even 10%.
Regards,
Remix
https://linustechtips.com/topic/716279-question-about-wifi/#findComment-9127222
