Right now I have the phanteks evolv tg but that was before I decided to water cool I was wondering what would be a good case to water cool with I would like to keep it under 200 if can ordering the parts soon.
PC Build
Ryzen 1800x
Asus Strix 1080ti
G-Skill Trident z RGB 32gb 3200mhz
Gigabyte K7 motherboard
NZXT Kraken x62
EVGA Supernova P2 850w
Phanteks Enthoo Evolv ATX TG
SAMSUNG 960 EVO M.2 1tb
Seagate Barracuda 3tb
Gigabyte WiFi and Bluetooth Card
x3 NZXT Aer RGB Fans
NZXT Hue
https://linustechtips.com/topic/715489-case-for-watercooling/
Define S!
Sig under construction.
https://linustechtips.com/topic/715489-case-for-watercooling/#findComment-9119576
CASE: deepcool dukase v2 MOTHERBOARD: Gigabyte gaming 3 CPU: intel core i5 6500 GPU: Gigabyte gtx 1070 g1 gaming CPU COOLER: enermax liqmax II 120s SSD: Kingston ssdnow uv400 240gb RAM: crucial ballistic sport (1 x 8) PSU: Cooler Master GX 650W
https://linustechtips.com/topic/715489-case-for-watercooling/#findComment-9119578
5 minutes ago, Tedster said:
Define S!
What's the difference between this and the define c I was looking into that one
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/715489-case-for-watercooling/#findComment-9119602
if you can deal with having a thinner radiator stick with the case you've got, just wish they would make a full tower version ngl
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
https://linustechtips.com/topic/715489-case-for-watercooling/#findComment-9119607
Good question! I didn't know there was such thing as the Define C...
Immediate impressions are:
1) The C wouldn't support radiators in the bottom because of its PSU shroud
2) The C doesn't seem to support 360mm radiators in the top
Both of which I believe the S can do.
https://linustechtips.com/topic/715489-case-for-watercooling/#findComment-9119617
So this should work?
https://pcpartpicker.com/list/Q4BdM8
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/715489-case-for-watercooling/#findComment-9119647
  Reveal hidden contents
What do you want in the case? How many / which radiators? Atx mAtx or eatx Mainboard? Do you want a tempered glass side panel?
https://linustechtips.com/topic/715489-case-for-watercooling/#findComment-9122540
Corsair Air 540
Thermaltake Core X9 (or X5, or X71)
There are loads of good cases out there for less than $200
18 hours ago, Tedster said:
Define S!
Anything not by Fractal, as sound dampening = poor airflow = poor thermal performance.
Not to mention that you're water cooling so sound will already be at a minimum.... (don't waste your money on that overhyped garbage)
Dubs are better than subs
https://linustechtips.com/topic/715489-case-for-watercooling/#findComment-9122933
3 hours ago, Trik'Stari said:
Corsair Air 540
I don't know how many radiators I was going to watch some more videos on it and my part list is in my post and I would like a side panel yes. And if not fractal then what? Should I see what other people did it in?
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/715489-case-for-watercooling/#findComment-9123989
Corsair Air 540
The x71 looks good would that be a good case to do it in kind of reminds me of a smaller 900d with less length
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/715489-case-for-watercooling/#findComment-9124001
To me the x71 looks much nicer thanks for bringing this to my attention are there any others you would recommend?
PC Build
Ryzen 1800x
Asus Strix 1080ti
NZXT Kraken x62
NZXT Hue
https://linustechtips.com/topic/715489-case-for-watercooling/#findComment-9124201
The other new corsair models 460 and the 5xx version.  Owning a 540 I really wanted a 740 but can't bring myself to do it.
Knowing how many rads you need will depend on the hardware so it's best to pick the case after all of that.
https://linustechtips.com/topic/715489-case-for-watercooling/#findComment-9126504
