1 minute ago, Tedster said:
Is it meant to be an external or internal drive? What controller are you connecting through?
And there isn't anything particularly wrong with it being marked that way I don't think...
It's an internal drive. It's on the first SATA port on my Motherboard.
https://linustechtips.com/topic/715478-hard-drive-removable/#findComment-9119467
17 minutes ago, Jbreezy2322 said:
My computer for some reason is recognizing my 3TB Toshiba HDD as ejecutable media. How do I fix this?
i can eject my C: drive lmoa, gonna try it
CPU: Intel9-9900k 5.0GHz at 1.36v  | Cooling: Custom Loop | MOTHERBOARD: ASUS ROG Z370 Maximus X Hero | RAM: CORSAIR 32GB DDR4-3200 VENGEANCE PRO RGB  | GPU: Nvidia RTX 2080Ti | PSU: CORSAIR RM850X + Cablemod modflex white cables | BOOT DRIVE: 250GB SSD Samsung 850 evo | STORAGE: 7.75TB | CASE: Fractal Design Define R6 BLackout | Display: SAMSUNG OLED 34 UW | Keyboard: HyperX Alloy elite RGB |  Mouse: Corsair M65 PRO RGB | OS: Windows 10 Pro | Phone: iPhone 11 Pro Max 256GB
https://linustechtips.com/topic/715478-hard-drive-removable/#findComment-9119509
Just now, Tedster said:
Nnnot a good idea, your machine will probably just crash
good, i need a reason to reboot ;)
https://linustechtips.com/topic/715478-hard-drive-removable/#findComment-9119520
Lol
just wondering what could go wrong besides it crashing
https://linustechtips.com/topic/715478-hard-drive-removable/#findComment-9119532
9 minutes ago, SCHISCHKA said:
whats the problem? all of my internal drives are 'ejectable'
My other computers never did it before. It displays like it's a flash drive. A window pops up in windows and says what would you like to do with this drive: "Toshiba (D:)"
https://linustechtips.com/topic/715478-hard-drive-removable/#findComment-9119537
It shouldn't do anything else, it shouldn't be able to write any garbage data or anything like that to the drive.
besides it has my OS on it lmao gonna try it brb
https://linustechtips.com/topic/715478-hard-drive-removable/#findComment-9119541
2 minutes ago, Tedster said:
So I see!
https://www.youtube.com/watch?v=bZYdJMjlKQ4
https://linustechtips.com/topic/715478-hard-drive-removable/#findComment-9119554
so go to control panel and change the way windows is mounting the drive. there is nthing wrong with the drive, just the way windows is handling it
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/715478-hard-drive-removable/#findComment-9119558
I...can't read the error it gave you in the video.
its still rendering, 360p lmao, recorded in crispy 1080p60fps :)
https://linustechtips.com/topic/715478-hard-drive-removable/#findComment-9119562
its finished rendering
https://linustechtips.com/topic/715478-hard-drive-removable/#findComment-9119595
7 hours ago, Jbreezy2322 said:
What program do you have running on the right side of your screen that gives you all your CPU and gpu temps?
Ill have to check
-will update when i know-
https://linustechtips.com/topic/715478-hard-drive-removable/#findComment-9120952
