Broken power supply?
12 hours ago, Sheenthesheeps said:Hello, I have a store bought PC (couple years old), I believe it is this one to be exact https://www.amazon.com/Gateway-DX4870-UR3D-Processor-Discontinued-Manufacturer/dp/B00EY524JC . The other day it refused to turn on, I could be wrong but I'm guessing the power supply died, so two questions. Is it possible to safely test if the power supply is broke? Also if a replacement is necessary, is it possible to get one that's too powerful (current ones 300W), say risk frying the motherboard or something?
It usually will turn on if the PSU is dying, it just won't run for very long under any amount of stress. If it has a dGPU then take it out and see if it runs without it just fine. That's usually a telltale sign it's gone.
Also no, no such thing as a PSU that's capable of outputting more wattage doing damage due to that. The PSU will give out what's required to power the system.
