I am looking to build my first ever PC and would like to know what you think of it. I found the components using PC Part Picker but am getting a better operating system. The link is https://pcpartpicker.com/list/wc9BFd. If you have any advice for the build or just any advice for building the PC it would be greatly appreciated. PS the PC will be for gaming programming school work and possible light streaming.
https://linustechtips.com/topic/715041-my-first-pc-build/
seems pretty good, i would use less ram and in turn try and get a 1070. but depends on if your doing 1080p or 1440p
MF UH BEANS
https://linustechtips.com/topic/715041-my-first-pc-build/#findComment-9115504
You don't need case fan. Case has plenty
Personal experience, I have that monitor and you should change it asap. It is bad. Really bad.
SSd looks kinda expensive. Get MX300 and you will be better
You don't need Windows 10 Pro
The rest is very well put, nice PSU, good GPU
https://linustechtips.com/topic/715041-my-first-pc-build/#findComment-9115512
It's an all round good build, Just so many fans, you lacking subs on youtube? Lol. If you want cheap, high quality, pwm fans use the Artic F-12. Or the new silent wings 3 if you want well silence and do not care about price.
Systems built (personal) | 1. Bad Wolf (Has passed on to PC Heaven): https://ca.pcpartpicker.com/b/zX9WGX |  2. Red Husky: https://ca.pcpartpicker.com/b/Mwhypg
Systems built (for commission) | 1. Red Fox: http://ca.pcpartpicker.com/b/W4LD4D | 2. Not Namedhttp://ca.pcpartpicker.com/b/TMhqqs 3. Bad Wolf 2.0: https://ca.pcpartpicker.com/b/7p8Ycf upgraded Bad Wolf to an I3-7100 for my friend as a gift|
https://linustechtips.com/topic/715041-my-first-pc-build/#findComment-9115524
I was just looking at the case and decided to fill it up and am trying to get a cool red vibe to it I first based this build off of a completed build and they did the same fans and it turned out great
https://linustechtips.com/topic/715041-my-first-pc-build/#findComment-9115533
Here.  A much better build for exact same price
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler  ($34.88 @ OutletPC)
Motherboard: ASRock Z170M Pro4S Micro ATX LGA1151 Motherboard  ($96.88 @ OutletPC)
Memory: Avexir Core Series 16GB (2 x 8GB) DDR4-2400 Memory  ($69.99 @ Newegg)
Storage: Crucial BX200 240GB 2.5" Solid State Drive  ($59.99 @ B&H)
Storage: Toshiba Product Series:DT01ACA 1TB 3.5" 7200RPM Internal Hard Drive  ($46.89 @ OutletPC)
Video Card: Gigabyte GeForce GTX 1070 8GB Windforce OC Video Card  ($379.99 @ Newegg)
Case: Thermaltake Core V21 MicroATX Mini Tower Case  ($56.99 @ SuperBiiz)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($64.99 @ Newegg)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($89.99 @ NCIX US)
Monitor: Acer GN246HL 24.0" 1920x1080 144Hz Monitor  ($188.83 @ Jet)
Keyboard: Corsair Vengeance K65 Compact Mechanical Gaming Keyboard Wired Gaming Keyboard  ($59.99 @ Newegg)
Mouse: Logitech G402 Wired Optical Mouse  ($36.00 @ Amazon)
Headphones: Kingston HyperX Cloud Stinger  Headset  ($49.99 @ Best Buy)
Total: $1465.39
Generated by PCPartPicker 2016-12-31 00:16 EST-0500
https://linustechtips.com/topic/715041-my-first-pc-build/#findComment-9115537
Have you used the case also
https://linustechtips.com/topic/715041-my-first-pc-build/#findComment-9115538
Total: $1465.39
this is a wayyyyyyyyyyyyy better build, and i have those headphones, the bass is lit af imo, but my last pair of headphones were 13 bucks, sooo
MF UH BEANS
https://linustechtips.com/topic/715041-my-first-pc-build/#findComment-9115539
If you wouldn't mind would you explain why this is so much better just curious
https://linustechtips.com/topic/715041-my-first-pc-build/#findComment-9115559
Use magnetic led strips if you can find them too light a case up, fans are okay. Just LED strips are WAY BETTER I know from experience. Also, with those af and sp the brightness depends on the speed since they use voltage to control there speed. The new ML 120&140 are not affect by voltage since they are pwn and getting 12v all the time. Make sure you even have enough fan headers on your mobo/splitters to power them all.
https://linustechtips.com/topic/715041-my-first-pc-build/#findComment-9115564
To give you another option. This would do better actually
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor  ($294.99 @ Newegg)
Motherboard: Asus H110M-A/M.2 Micro ATX LGA1151 Motherboard  ($44.99 @ Amazon)
Keyboard: Corsair STRAFE Wired Gaming Keyboard  ($69.99 @ Newegg)
Total: $1453.62
Generated by PCPartPicker 2016-12-31 00:21 EST-0500
https://linustechtips.com/topic/715041-my-first-pc-build/#findComment-9115565
A 1070 is better than your 1060
An overclockable 6600k which will be better than your i5 6500
Monitor is better and 144hz to make everything smoother
Better keyboard and mouse
https://linustechtips.com/topic/715041-my-first-pc-build/#findComment-9115570
Ok thanks but the reason i did a 2x16 ram was because it allowed for upgrade ability without have to sell or throw the old stuff out for a while
https://linustechtips.com/topic/715041-my-first-pc-build/#findComment-9115582
