That CPU is very old and won't be compatible with your mobo
"You don't need headphones, all you need is willpower!" ~MicroCenter employee
How to use a WiiMote and Nunchuck as your mouse!
Specs:
Graphics Card: EVGA 750 Ti SC
PSU: Corsair CS450M
RAM: A-Data XPG V1.0 (1x8GB) (Red)
Procrastinator: Intel i5 4690k @ 4.4GHz 1.3V
Case: NZXT Source 210 Elite (Black)
Speakers and Headphones: Monitor Speakers and Phlips SHP9500s
MoBo: MSI Z97 PC MATE
SSD: SanDisk Ultra II (240GB)
Monitor: LG 29UM68-P
Mouse: Mionix Naos 7000
Keyboard: Corsair K70 RGB (2016) (Browns)
Webcam/mic: Logitech C270
https://linustechtips.com/topic/714968-i-need-help/#findComment-9114972
2 minutes ago, SCHISCHKA said:
I don't know what you're trying to say. There's no point in buy that CPU, and OP has an 1151 socket mobo chosen.
Specs:
PSU: Corsair CS450M
https://linustechtips.com/topic/714968-i-need-help/#findComment-9115008
im confirming your post. im saying its a 1155 socket
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/714968-i-need-help/#findComment-9115042
1 minute ago, Bleedingyamato said:
Yeah, 8GB would be a suitable minimum.  16GB is more for "just to sure you won't likely need more anytime soon".
i bought 16GB five years ago. iv never needed it but i can get away with no swap. things might be different with GPU reaching 8GB VRAM now
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/714968-i-need-help/#findComment-9115074
Idk if I've gotten anywhere near running low on available RAM either but it's nice to know I have more than I need.
Why would more VRAM affect how much RAM you'd need?
https://linustechtips.com/topic/714968-i-need-help/#findComment-9115191
there is a relationship. I would aim for equal or greater system ram to vram; there used to be a 4:1 ratio recommendation but that is outdated. i think its due to system ram gets reserved for addressing; there was a blog post on MSDN from a MS engineer explaining it but i cannot find it. Nvidia atm states min 4GB for the 10 series and 2GB for some older cards
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/714968-i-need-help/#findComment-9115270
I'm curious why there is a relationship.
https://linustechtips.com/topic/714968-i-need-help/#findComment-9115530
i couldnt find the MSDN article. its to do with virtual page addressing, more vram = more addresses required. theres also stages in the graphics pipleine where data gets transferred between cpu and gpu. theres an amount of system ram that windows reserves for graphics and that pretty much increases every generation
ψ ︿_____︿_ψ_
https://linustechtips.com/topic/714968-i-need-help/#findComment-9115586
Ok.  I think it's enough for now to know that having enough RAM is a good idea.
https://linustechtips.com/topic/714968-i-need-help/#findComment-9115906
I can build a PC with these things. MSI GeForce GTX 1050 Ti 4GB Gaming X, HyperX Fury DDR4 2133MHz 16GB or Corsair Vengeance LPX DDR4 2133MHz 16GBMSI B150A GAMING PRO, Socket-1151, intel (r) core(TM) i7-2700k cpu @ 3.50GHz, Corsair CX750, 750W PSU,Corsair Carbide 300R Midi Tower Sort.  that works??
https://linustechtips.com/topic/714968-i-need-help/#findComment-9127298
No you can't the i7 2700K supports the LGA 1155 socket only and the B150 supports the LGA 1151 socket only.
زندگی از چراغ
Intel Core i7 7800X 6C/12T (4.5GHz), Corsair H150i Pro RGB (360mm), Asus Prime X299-A, Corsair Vengeance LPX 32GB (4X4GB & 2X8GB 3000MHz DDR4), MSI GeForce GTX 1070 Gaming X 8G (2.113GHz core & 9.104GHz memory), 1 Samsung 970 Evo Plus 1TB NVMe M.2, 1 Samsung 850 Pro 256GB SSD, 1 Samsung 850 Evo 500GB SSD, 1 WD Red 1TB mechanical drive, Corsair RM750X 80+ Gold fully modular PSU, Corsair Obsidian 750D full tower case, Corsair Glaive RGB mouse, Corsair K70 RGB MK.2 (Cherry MX Red) keyboard, Asus VN247HA (1920x1080 60Hz 16:9), Audio Technica ATH-M20x headphones & Windows 10 Home 64 bit.
The time Linus replied to me on one of my threads:
https://linustechtips.com/topic/714968-i-need-help/#findComment-9127309
No. the I7-2700k is socket-1155. It also uses DDR3 not 4.
CPU: I5 4590 Motherboard: ASROCK H97 Pro4 Ram: XPG 16gb v2.0 4x4 kit  GPU: Gigabyte GTX 970 PSU: EVGA 550w Supernova G2 Storage: 128 gb Sandisk SSD + 525gb Mx300 SSD Cooling: Be Quiet! Shadow Rock LP Case: Zalman T2 Sound: Logitech Z506 5.1 Mouse: Razer Deathadder Chroma Keyboard: DBPower LED
https://linustechtips.com/topic/714968-i-need-help/#findComment-9127310
^ Use pcpartpicker.com for compatibility help
https://linustechtips.com/topic/714968-i-need-help/#findComment-9127326
30 minutes ago, sondrejr said:
if i use intel Core i7-6700K Skylake with the  MSI B150A GAMING PRO, Socket-1151?? can i build a pc that is good then?
No, you need a Z170 Motherboard to overclock it.
https://linustechtips.com/topic/714968-i-need-help/#findComment-9127622
