Nikolai at https://superuser.com/questions/547822/how-many-passes-are-enough-with-memtest#550641 said that memtest stresses the CPU. Which has me worried here. Does Memtest stress test your CPU?
I have a decent cooler but I have not installed it yet. I currently have the stock cooler and I am unsure if the paste was applied correctly. You never truly know until you take it off.
https://linustechtips.com/topic/714938-does-memtest-stress-test-cpu/
It does, but I wouldn't just run memtest if you want to stress test CPU and memory. Also memtest doesn't allow you to look at temps as it's a bootable environment, so make sure your cooler can handle 100% load before running it.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
2 minutes ago, Electronics Wizardy said:
Stock cooler is more than enough for a cpu, it will power off if it overheats, and it will also thermal throttle so it doesn't overheat.
It uses some cpu, don't worry about it.
I know some of the CPU is being used, But it it going to 100%?
Memtest shows CPU temps in the top left, I noticed. My CPUs temperature was 95 degrees for about half an hour.
Just booted into BIOS after shutting it down and my CPUs temp is floating around 60 degrees celcius, which is pretty abnormal. This has me worried now.
60C idle is really worrying. Mind listing your specs? You might need to reseat cooler and reapply thermal paste. Idle should be closer to 40C or under.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
Oh I thought I had already done that.
https://uk.pcpartpicker.com/list/MGbkhM
Im using the stock cooler.
16 minutes ago, Alir said:
I don't care about 60 degrees. Im more concerned about 90 degrees.
With that cooler 60C idle is way too high. It should be well under 40C.
