You can overlock the i5 6600k and you cant overclock i5 6600.
i5 6600k doesent come with stock cooler but i5 6600 does.
If you want to overclock i5 6600k you will need more expensive Z170 motherboard.
i5 6600k has slightly higher base and boost clock over i5 6600 but its not really worth the price extra alone and you should get it only if you want to overclock.
https://linustechtips.com/topic/714720-help-i-need-advice/#findComment-9112389
The 6600k can be overclocked and comes with a slightly higher base clock. However, the 6600 comes with a stock cooler and is cheaper overall. For gaming there will probably be a minuscule difference. Give us more information.
My main computer:
i7 6700k || GTX 1070 || Asus Z170 RGB || C.M. Hyper 212 EVO || 16GB RAM || 256GB NVMe SSD || 500GB SATA SSD || 12TB total HDD || Define R5 Blackout || 850W PSU
More Details Below :)
CPU: Intel Core i7 6700k                             GPU:  EVGA GTX 1070 FTW                                  |  Motherboard: Asus Z170 Pro Gaming Aura
CPU Cooler: C.M. Hyper 212 EVO             RAM: 16GB Kingston Fury 4x4 DDR4 2400MHz         SSD:  Intel 256GB NVMe SSD & Plextor 500GB SATA SSD
Hard Drive:  WD 2TB Black, 2TB WD Blue, 8TB WD Red     Case:  Fractal Design Define R5 Blackout Edition   PSU:  Be Quiet! Dark Power Pro 11 850W
Additional Computer Parts: NZXT Hue for LEDs
Peripherals: Dell U2414H (x2) || Corsair Sabre RGB || Corsair K95 Platinum || Sennheiser 558's || Modmic
Pictures of setup:
https://linustechtips.com/topic/714720-help-i-need-advice/#findComment-9112397
