I got my grandfather sennheiser headphones for Christmas. he is into amateur radio. the radio only produces a mono sound so on ear doesn't play anything. Is their anyway i can use a splitter or something to make the mono sound play int both ears?
LOOK AT MY NEW FLAG DESIGNS FOR PA AND VOTE ON YOUR FAVORITE
LOOK AT MY FIRST BATCH OF DESIGNS HERE
4690K @ 4.5GHz
GTX 970 FTW
MSI Z97 PC MATE
Define R5 windowed
Cooler Master Seidon 240m
EVGA SuperNOVA 650 G1
Kingston 120gb SSD
SanDisk 480Gb SSD
Seagate 1Tb Hard drive
https://linustechtips.com/topic/714700-mono-to-stereo-need-help/
You could certainly build one. That's some of the draw to amateur radio is this sort of stuff. Bridging the pins is what you need.
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/714700-mono-to-stereo-need-help/#findComment-9112186
well he's 83. but i can't buy something that duplicates the 1 channel signal over 2 channels?
4690K @ 4.5GHz
GTX 970 FTW
MSI Z97 PC MATE
Define R5 windowed
Kingston 120gb SSD
SanDisk 480Gb SSD
https://linustechtips.com/topic/714700-mono-to-stereo-need-help/#findComment-9112199
Sure you could, but that's so boring. He might be elderly, but electronics is in the blood of a ham.
Search for mono to stereo adapters on Amazon. Make sure to buy the correct size plug.
System specs:
https://linustechtips.com/topic/714700-mono-to-stereo-need-help/#findComment-9112233
Thanks for the help
4690K @ 4.5GHz
GTX 970 FTW
MSI Z97 PC MATE
Define R5 windowed
Kingston 120gb SSD
SanDisk 480Gb SSD
https://linustechtips.com/topic/714700-mono-to-stereo-need-help/#findComment-9112293
