So i just got my new, second hand, AMD R9 280X Sapphire Dual X 3Gb graphics card and i finally (i don't have the fastest net around) installed Doom and im running it, eh, pretty okay i guess, i mean it looks pretty good but i know it can do better with Vulkan. So here's the issue, my old R7 240 could run Vulkan (although performance was even more dead then with OpenGL) but now everytime i choose the Vulkan API, Doom doesn't even want to start, only sends me a crash report. And the only things that changed since the time i tried running are the Doom version, my GPU, my PSU (obvious reasons) and the drivers. So i will appreciate whatever help i can get.
https://linustechtips.com/topic/714212-doom-vulkan-crash-problem/
18 minutes ago, Veczen said:
and the drivers.
Have you tried using DDU (Display Driver Uninstaller) and downloading+installing new drivers again?
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
Did you just install the card without reinstalling your drivers?
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
Oh yeah, i forgot to mention but i downloaded and clean installed all the drivers with the option that was included in the AMD Install thingy, so drivers are super up to date.
Sorry for being a bit late with the response, was playing competitive CS:GO.
  • 2 months later...
On 18/03/2017 at 0:46 AM, UjLion said:
Try replacing vulkan-1.dll with vulkan-1-1-0-21-0.dll in %Windows%\System32.
See my full solution here: https://ujnotes.com/computer/game/doom/2016/demo/issue/vulkan_crash that worked for the Demo
Sorry to say this but i finished the game quite a long time ago now. Still thanks for trying. I might try that if i decide to replay it again someday.
For how i solved the problem. Well i just ran the game with Windows 10 instead of 7, since i have the luxury of dual boot. But i still do prefer Windows 7 over 10.
