Hello there i just bought most of my parts today from newegg but i was not sure about the ram i should go with.
can you gives recommend some i will link my new build items and i will link the last things i need to buy bellow these but i don't know what ram to use.
Intel Core i7-6700K Skylake Quad-Core 4.0 GHz LGA 1151 91W BX80662I76700K Desktop Processor Intel HD Graphics 530
CORSAIR RMx Series RM850X 850W 80 PLUS GOLD Haswell Ready Full Modular ATX12V & EPS12V SLI and Crossfire Ready Power Supply
GIGABYTE G1 Gaming GA-Z170X-Gaming 7 (rev. 1.0) LGA 1151 Intel Z170 HDMI SATA 6Gb/s USB 3.1 USB 3.0 ATX Intel Motherboard
MSI GeForce GTX 1080 DirectX 12 GTX 1080 GAMING X 8G 8GB 256-Bit GDDR5X PCI Express 3.0 x16 HDCP Ready SLI Support ATX Video Card
Corsair Hydro Series H110i Extreme Performance Water / Liquid CPU Cooler Cooling. 280mm CW-9060026-WW
Items left to buy
IN STOCK
LIMIT 5
  • $159.99
  • $118.99
  • Save: 25.63%
IN STOCK
  • $99.99
1
IN STOCK
  • $79.99
  • $0.00
  • Save: 100.00%
IN STOCK
LIMIT 2
  • $48.99
  • $47.49
https://linustechtips.com/topic/713875-new-build-help/
1 minute ago, deXxterlab97 said:
Good. Don't buy that SSD. IT is bad
Corsair or GSkill RAM are fine. Though any should do. 2x8
Ditto. I'd trust my old SSD from 2011 before that particular Kingston drive.
For good performance for the dollar ram, G.Skill Ripjaws and Corsair Vengeance series ram is good. In spite of the SSD, Kingston Fury ram is pretty good.
https://linustechtips.com/topic/713875-new-build-help/#findComment-9104110
3 minutes ago, Legacyxblood401 said:
OK i just don't know  platinum of trident.
Don't waste the cash on blingy meme ram, not worth it. Better with the Vengeance series if Corsair and use the saved cash for a better SSD
Edit: or get the Trident, those look bomb
https://linustechtips.com/topic/713875-new-build-help/#findComment-9104116
Dominator Platinums are a bad buy when the TridentZs are more or less the same at a significantly lower price. 3000MHz would be the ideal 'sweetspot' frequency.
And yeah, don't get that SSD. Something like the Crucial MX300 would be a good choice.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/713875-new-build-help/#findComment-9104117
