hello,
this is my first pc build every thing was working fine i went into the bios and it was working everything was identified correctly but suddenly everything went off. Now nothing is working no led indication on motherboard nothing when i try to power it on. i removed everything and made sure that there was nothing under the motherboard that can short it. I reinstalled my cpu gpu ram and all the wires multiple times and made sure that everything was wired up correctly what should i do now im so worried and cant think of any solution for this.
https://linustechtips.com/topic/713737-need-help/
Just now, LabRat said:
if it booted for 2 seconds and now it won't.......... try flipping the switch on the back of the power supply. maybe you turned it off?
nope it booted for a good 5 minutes and i restarted the pc to make sure everything was fine and i closed the case 5 minutes later it was powered off by itself and nothing wanted to work after that
https://linustechtips.com/topic/713737-need-help/#findComment-9102808
14 minutes ago, blueflame said:
i heard that this power supply is a very good power supply, my problem is that nothing is booting or working no fans or motherboard leds should i remove everything away from the case and try to boot it on the motherboard box?
You are right it's a  good power supply but when the psu fails nothing else can work. When I asked you to remove all wires to test if the psu is working I meant all wires except the powercord so if you understood me wrong the first time u should try it again and if u got me right u probaply need a new psu.
https://linustechtips.com/topic/713737-need-help/#findComment-9102833
