Hey everyone,  a friend of mine sent me here to see if you guys could help me out.
For the last week my pc has been shutting down with no apparant reason.
It all started since i put new parts into my pc (Motherboard, Processor and RAM)
I've tried updating all my drivers
Done countless windows reinstalls
even tried w8.1 instead of w10
To be honest i don't know what to try anymore.
i'll be putting back my old parts tomorrow to see if i'll still have the problems.
If you guys know anything that might work out, please let me know!
EDIT:  https://pcpartpicker.com/list/qdd88K  Parts list!
Old parts were:
MOBO: ASUS M5A78L-M/USB3
Processor: AMD vishera FX-8320, eight core
Crucial balistix sport 12gb ddr3-1600
https://linustechtips.com/topic/713676-help-required-pc-shuts-down/
Might sound dumb but make sure your thermal paste is properly applied to your CPU and the cooler is seated correctly.
Ryzen 9 3950x - 64 GB DDR4 - NVME 980 pro SSD - EVGA RTX 3080 FTW Ultra - FAD CASE
Full custom loop / links below out of date
LTT Build Log | PCPP Build Log
_____________________________________________________________________________________________
Sorry if I stop responding, I've probably gotten busy as I mostly am only on here while working.
Welcome to the Forum!
The most obvious thing to me would be the power supply.
Also out of curiosity, could you list the specs?
Sig under construction.
Also, what are the components? Full list including how many watts your power supply is. As well as exactly what is happening, for example, does it only crash while gaming? Does it crash every time after being on for 20 minutes? Whatever is going on. That way we can help you trouble shoot the problem a bit better.
Just now, jeffmeyer5295 said:
Also, what are the components? Full list including how many watts your power supply is. That way we can help you trouble shoot the problem a bit better.
It's not all about the wattage rating, it's about how old it is, whether it's been abused etcetera (:
Exactly.
Just now, ArkTheYO said:
i guess it could be a Ram issue, trying the old swap out swap in ram trick and then boot.
I tried that, unfortunately no change..
I hear that from everyone, but after having multiple people check my new parts against my old parts.. the new parts take less wattage so there should be no problem at all..
good thing i made a (SEMI COMPLETE) pc partpicker list:  https://pcpartpicker.com/list/qdd88K
i'll also edit it into the main post
im certain its seated correctly, but i never actually though about the paste! i'll look into that as soon as i can! thanks!
I'm relatively adamant that it's the power supply, the things are that the combined TDPs aren't wholly representative of the actual power draw, that you might be drawing different amounts from different rails than you were before, and that power supplies degrade over time.
As of yeti t has only done it whilst gaming (But also right when i just start up a game after doing pretty much nothing for hours before)
7 minutes ago, losBaumos said:
So to clearify that the pc boots correctly?
aside for the sometimes random BIOS boot it boots normally without any problems
If you never thought about the Thermal paste that might very well be your issue, considering that cooler does not come with it pre-applied, you have to put it on yourself(you may have)
The only reason why I say that is because I trouble shoot custom built computers on a regular basis in person, what you're describing sounds like the pc is shutting itself off to avoid damage.
And I wouldn't throw out the power-supply issue right away, they are very sensitive and can fail at any time for no clear reason.
3 minutes ago, losBaumos said:
So I would remove all unnecassary parts and try if it runs stable for an longer time.
adding/removing parts until its stable is a very long and annoying troubleshooting process but will help tell you if it is the psu causing issues.. I recommend using Windows memory diagnostic in the start menu to test the ram, maybe run a stress test on the CPU to see if it overheats and shuts down(not safe if my theory is right about thermal paste), test the drives. there could be a lot of things causing your issue.
adding/removing parts until its stable is a very long and annoying troubleshooting process. I recommend using Windows memory diagnostic in the start menu to test the ram, maybe run a stress test on the CPU to see if it overheats and shuts down(not safe if my theory is right about thermal paste), test the drives. there could be a lot of things causing your issue.
The Windows memtest is pretty bad in my experience, I'd recommend memtest86+ instead. Or memetest86+ if you for some reason want to see a rare Pepe on your screen...
1 minute ago, Godchildcain said:
Looking through my windows event vieuwer i'm seeing error codes 7034. 219, 6008 and 41 around the times of shutdown.
i hope this helps in solving the issue
Those are just all unexpected shutdown codes it appears, which just confirms what we already know: the system is shutting down/rebooting without the operating system calling for it.
Tried the 3Dmark stress test. these are the results  https://gyazo.com/bf41b68258b7978d66e38abbd3042927
Unfortunately the only thing i can disconnect (because i don't need them) are the 2 HDD's.
Today for instance i reinstalled windows at 16:00 and it ran nearly perfectly untill just now, 22:17 when it crashed again.
sometimes it takes for ever to crash again.
I'm betting on that power supply, here's a YouTube video showing it having ripple in excess of 100mv, which is crazy:
Seriously, that kind of ripple can damage components in the long run, and can cause stability issues by itself, and who knows what else is wrong with that PSU.
Current LTT F@H Rank: 24    Score: 10,097,484,643   Stats
Yes, I have 9 monitors.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
Cooler: Noctua NH-D15
Mobo: Asus ProArt X670E Creator WiFi
RAM: 96GB Trident Z Neo @6400 CL32
GPU: RTX 4090 Founders Edition, Radeon Pro WX 5100
PSU: Corsair RM1000e
SSDs: Samsung 990 Pro 4TB NVME, Samsung 970 evo plus 1TB NVME, 2x Samsung 870 evo 2TB, Samsung 860 evo 1TB, Samsung 970 evo 500GB NVME
Case: Fractal Design Define R5 Black w/ Tempered Glass Side Panel Upgrade
Monitors: 9 Monitors: Alienware AW3423DWF 3440x1440@165Hz, Acer H236HLbid 1080p@77Hz, HP D7z72AA 1080p@60Hz, Dell Inspiron 24 3459 1080p@60Hz(used only as display), Dell U2724D 1440p@120Hz, ASUS VP228 1080p@60Hz, 2x HP ZR2440W 1200p@60Hz
unRAID server (Plex, Backups, NAS, Duplicati, game servers):
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
Cooler: Noctua NH-U9S
Mobo: Asus ROG Strix X470-F
RAM: 64GB G-Skill Ripjaws V @ 3200MHz
PSU: EVGA G3 850W
Total Storage: Raw: 94TB, Usable: 64TB
SSD: Samsung 990 Pro 2TB NVME, Teamgroup 4TB NVME
HDDs: 4x HGST Dekstar NAS 4TB @ 7200RPM (3 data, 1 parity) + (7x Seagate Ironwolf NAS 8TB + 2x Toshiba N300 NAS 8TB in ZFS)
Case: Fractal Define 7 XL
Other: Added 3x Noctua NF-F12 intake, 2x Noctua NF-A8 exhaust, Inatek 5 port USB 3.0 expansion card with usb 3.0 front panel header
6 hours ago, Godchildcain said:
Any PSU you guys could recommend me?
(Around 200 euros is my MAX budget)
I'm taking out my HDD's now to see if i still crash.
Anything tier 3 or higher from here:
With that budget you should be able to get a tier 1, but its up to you.
My main PC:
OS: Windows 11
CPU: Ryzen 9 9950X
OS: unRAID 7.1.4
CPU: Ryzen R9 3900X
PSU: EVGA G3 850W
