Ubiquitii AP PRO
Solved by harry4742,
okay standard network setup looks like this
your ISP line (modem) goes into your router/firewall here security gateway (ill call it router)
then there is a switch because your router dosnet have enough ports
then the AP goes to the Switch just as any other wired device (like your PC)
now your router has to tell your clients (pcs notebooks phones cloud-key...) who he is (DHCP Server) so your pc needs the IP address of your router as Gatewayaddress and it needs the ip of a DNS-Server (like 8.8.8.8 for google)
your router might also need information about your connection to the ISP and did you throw out your ISPs router, if not the problem might be NAT
