Hello guys
i Would like to hear you opinion on this pc i put together on pc part picker
i Got no max bugdet. So long the parts is Black and orange or full rgb
im open for suggestions
https://pcpartpicker.com/list/9XMCCy
And only Choose the Big psu. So i could upgrade too multiple gpu's and more ssd's and so on
best regrads
Kevin P
https://linustechtips.com/topic/713058-gaming-pc-help/
5 hours ago, EazYKevin said:
Hello guys
best regrads
Kevin P
some bequite cases are orange
https://linustechtips.com/topic/713058-gaming-pc-help/#findComment-9095518
when you say no budget you mean absolutly no budget?
Omega-  I5 6600k | Gigabyte GTX 1060 | Cougar Panzer | DDR4 16GB 3000MHz | MSI Z170 Gaming M5
               EVGA 650 GQ | AOC 60Hz Freesync Panels x2 | AOC 144hz Freesync Panel x1
Epsilon- I7 2700k | Asus GTX 970 | Corsair 780t | DDR3 8GB 1600MHz | EVGA Z68 FTW Mobo
               Corsair 750W G2 | Acer R240HY x2
Upsilon- i7 5500u | 6GB DDR3 | 720p 60Hz panel
https://linustechtips.com/topic/713058-gaming-pc-help/#findComment-9095532
850W should be enough for two 1080s so 1000W should really be more than enough. It depends on what you use it for but I would get for about the same money the 5820k and the Asus X99 Strix motherboard, because this Combo would mean a lot more CPU power. And I guess you really need a M.2 SSD, cause you are of Course a Video editor and not a gamer, who wouldn't see barely any benefits from such a SSD.
i5 6500 @3.2Ghz, Zotac GTX 1080 Ti Mini, 16GB DDR4 @2400Mhz, 240GB SSD, 1TB HDD, Corsair Vengance 650W, Asus Z170 Pro Gaming, Thermaltake Versa U21, Hyper 103
AOC Agon AG271UG 27" 4k G-Sync, G933, G502, G801
https://linustechtips.com/topic/713058-gaming-pc-help/#findComment-9095552
I dont do much video editing. More computetive Gaming, but im kinda new to building pc's so i can be all wrong whit These parts :)
https://linustechtips.com/topic/713058-gaming-pc-help/#findComment-9095571
nothing to crazy :( i just spent like 15 minutes doing this
PCPartPicker part list: https://pcpartpicker.com/list/D8mCCy
Price breakdown by merchant: https://pcpartpicker.com/list/D8mCCy/by_merchant/
CPU: Intel Core i7-6950X 3.0GHz 10-Core Processor  ($1579.99 @ SuperBiiz)
CPU Cooler: NZXT Kraken X62 Liquid CPU Cooler  ($159.99 @ B&H)
Motherboard: Asus ROG STRIX X99 GAMING ATX LGA2011-3 Motherboard  ($319.99 @ SuperBiiz)
Memory: Corsair Dominator Platinum 16GB (4 x 4GB) DDR4-3400 Memory  ($239.99 @ Newegg)
Storage: Samsung 960 Pro 2.0TB M.2-2280 Solid State Drive  ($1299.99 @ B&H)
Storage: Seagate BarraCuda Pro 10TB 3.5" 7200RPM Internal Hard Drive  ($476.44 @ Newegg Marketplace)
Video Card: Asus GeForce GTX 1080 8GB STRIX Video Card (2-Way SLI)  ($678.99 @ SuperBiiz)
Case: be quiet! DARK BASE PRO 900 | ORANGE ATX Full Tower Case  ($214.99 @ NCIX US)
Power Supply: EVGA SuperNOVA T2 1600W 80+ Titanium Certified Fully-Modular ATX Power Supply  ($384.99 @ SuperBiiz)
Case Fan: Corsair HD120 RGB 3-Pack w/Controller 54.4 CFM  120mm Fans  ($89.99 @ B&H)
Total: $7643.65
Generated by PCPartPicker 2016-12-27 14:31 EST-0500
Edited by 21rkosta
That html code didnt work
https://linustechtips.com/topic/713058-gaming-pc-help/#findComment-9095573
<a href="https://pcpartpicker.com/list/D8mCCy">PCPartPicker part list</a> / <a href="https://pcpartpicker.com/list/D8mCCy/by_merchant/">Price breakdown by merchant</a>
<table class="pcpp-part-list">
  <thead>
    <tr>
      <th>Type</th>
      <th>Item</th>
      <th>Price</th>
    </tr>
  </thead>
  <tbody>
    <tr>
      <td class="pcpp-part-list-type">CPU</td>
      <td class="pcpp-part-list-item"><a href="https://pcpartpicker.com/product/MJM323/intel-cpu-bx80671i76950x">Intel Core i7-6950X 3.0GHz 10-Core Processor</a></td>
      <td class="pcpp-part-list-price">
        <a href="https://pcpartpicker.com/product/MJM323/intel-cpu-bx80671i76950x">$1579.99 @ SuperBiiz</a>
      </td>
    </tr>
    <tr>
      <td class="pcpp-part-list-type">CPU Cooler</td>
      <td class="pcpp-part-list-item"><a href="https://pcpartpicker.com/product/bqBrxr/nzxt-kraken-x62-liquid-cpu-cooler-rl-krx62-01">NZXT Kraken X62 Liquid CPU Cooler</a></td>
        <a href="https://pcpartpicker.com/product/bqBrxr/nzxt-kraken-x62-liquid-cpu-cooler-rl-krx62-01">$159.99 @ B&H</a>
      </td>
    </tr>
    <tr>
      <td class="pcpp-part-list-type">Motherboard</td>
      <td class="pcpp-part-list-item"><a href="https://pcpartpicker.com/product/L6rcCJ/asus-motherboard-rogstrixx99gaming">Asus ROG STRIX X99 GAMING ATX LGA2011-3 Motherboard</a></td>
        <a href="https://pcpartpicker.com/product/L6rcCJ/asus-motherboard-rogstrixx99gaming">$319.99 @ SuperBiiz</a>
      </td>
    </tr>
    <tr>
      <td class="pcpp-part-list-type">Memory</td>
      <td class="pcpp-part-list-item"><a href="https://pcpartpicker.com/product/hzyxFT/corsair-memory-cmd16gx4m4b3400c16">Corsair Dominator Platinum 16GB (4 x 4GB) DDR4-3400 Memory</a></td>
        <a href="https://pcpartpicker.com/product/hzyxFT/corsair-memory-cmd16gx4m4b3400c16">$239.99 @ Newegg</a>
      </td>
    </tr>
    <tr>
      <td class="pcpp-part-list-type">Storage</td>
      <td class="pcpp-part-list-item"><a href="https://pcpartpicker.com/product/FcGj4D/samsung-960-pro-20tb-m2-2280-solid-state-drive-mz-v6p2t0bw">Samsung 960 Pro 2.0TB M.2-2280 Solid State Drive</a></td>
        <a href="https://pcpartpicker.com/product/FcGj4D/samsung-960-pro-20tb-m2-2280-solid-state-drive-mz-v6p2t0bw">$1299.99 @ B&H</a>
      </td>
    </tr>
    <tr>
      <td class="pcpp-part-list-item"><a href="https://pcpartpicker.com/product/dqbkcf/seagate-barracuda-pro-10tb-35-7200rpm-internal-hard-drive-st10000dm0004">Seagate BarraCuda Pro 10TB 3.5" 7200RPM Internal Hard Drive</a></td>
        <a href="https://pcpartpicker.com/product/dqbkcf/seagate-barracuda-pro-10tb-35-7200rpm-internal-hard-drive-st10000dm0004">$476.44 @ Newegg Marketplace</a>
      </td>
    </tr>
    <tr>
      </td>
    </tr>
    <tr>
      </td>
    </tr>
    <tr>
      </td>
    </tr>
    <tr>
      <td class="pcpp-part-list-type">Video Card</td>
      <td class="pcpp-part-list-item"><a href="https://pcpartpicker.com/product/vzfmP6/asus-video-card-strixgtx1080o8ggaming">Asus GeForce GTX 1080 8GB STRIX Video Card</a> (2-Way SLI)</td>
        <a href="https://pcpartpicker.com/product/vzfmP6/asus-video-card-strixgtx1080o8ggaming">$678.99 @ SuperBiiz</a>
      </td>
    </tr>
    <tr>
      </td>
    </tr>
    <tr>
      <td class="pcpp-part-list-type">Case</td>
      <td class="pcpp-part-list-item"><a href="https://pcpartpicker.com/product/wrvZxr/be-quiet-dark-base-pro-900-orange-atx-full-tower-case-bgw10">be quiet! DARK BASE PRO 900 &#124; ORANGE ATX Full Tower Case</a></td>
        <a href="https://pcpartpicker.com/product/wrvZxr/be-quiet-dark-base-pro-900-orange-atx-full-tower-case-bgw10">$214.99 @ NCIX US</a>
      </td>
    </tr>
    <tr>
      <td class="pcpp-part-list-type">Power Supply</td>
      <td class="pcpp-part-list-item"><a href="https://pcpartpicker.com/product/v7PzK8/evga-power-supply-220t21600x1">EVGA SuperNOVA T2 1600W 80+ Titanium Certified Fully-Modular ATX Power Supply</a></td>
        <a href="https://pcpartpicker.com/product/v7PzK8/evga-power-supply-220t21600x1">$384.99 @ SuperBiiz</a>
      </td>
    </tr>
    <tr>
      <td class="pcpp-part-list-type">Case Fan</td>
      <td class="pcpp-part-list-item"><a href="https://pcpartpicker.com/product/mh7CmG/corsair-hd120-rgb-w-controller-544-cfm-120mm-fans-co-9050067-ww">Corsair HD120 RGB 3-Pack w/Controller 54.4 CFM  120mm Fans</a></td>
        <a href="https://pcpartpicker.com/product/mh7CmG/corsair-hd120-rgb-w-controller-544-cfm-120mm-fans-co-9050067-ww">$89.99 @ B&H</a>
      </td>
    </tr>
    <tr>
      </td>
    </tr>
    <tr>
      <td></td>
      <td class="pcpp-part-list-price-note">Prices include shipping, taxes, rebates, and discounts</td>
      <td></td>
    </tr>
    <tr>
      <td></td>
      <td class="pcpp-part-list-total">Total</td>
      <td class="pcpp-part-list-total-price">$7643.65</td>
    </tr>
    <tr>
      <td></td>
      <td class="pcpp-part-list-price-note">Generated by <a href="http://pcpartpicker.com">PCPartPicker</a> 2016-12-27 14:30 EST-0500</td>
      <td></td>
    </tr>
  </tbody>
</table>
Im sorry but Im too noob to even use all that ?
https://linustechtips.com/topic/713058-gaming-pc-help/#findComment-9095589
22 minutes ago, EazYKevin said:
And og 1000w watts is more then enough is this a good choose ?
EVGA SuperNOVA 1000 G2, 1000W PSU
Yes that should be fine.
So here is my part Suggestion for a very high end gaming PC:
i7 5820k (5930k, 6800k and 6850k are other viable options)
Asus ROG Strix X99 Gaming
2x GTX 1080s or a Titan XP (or 2 Titans if you want to throw Money out of the window)
Any PSU above 900W
Almost any 240mm AiO-Cooler
500GB SSD, Intel and Samsung are my favorites (M.2 only if you need that 2 seconds less loading time)
any 2-6TB HDD (I prefer WD Black)
16 or 32 GB of Ram (16 is more than enough but if you want you can get 32)
https://linustechtips.com/topic/713058-gaming-pc-help/#findComment-9095833
Any PSU above 900W
Is the older gen CPU and chipset better for Gaming ?
I just se so Many use 6700k and a Z170 motherboard
https://linustechtips.com/topic/713058-gaming-pc-help/#findComment-9095938
The older Chipset and the CPUs are part of Intel's extreme series, they are more expensive but a lot better.
Almost noone uses X99 just cause it is very expensive, but for me it would be the only choice for a super high end gaming rig.
If I was you I would wait for Zen, cause Zen might match the performence of a 6900k for a lot less money.
https://linustechtips.com/topic/713058-gaming-pc-help/#findComment-9096038
What is the zen ?
https://linustechtips.com/topic/713058-gaming-pc-help/#findComment-9096119
Zen or Ryzen is the new wave of high end CPUs by AMD that will come out in the spring of 2017.
And a short question, if it isn't too personal: From where are you, cause you don't seem as if you would be from any english speaking cuntry.
https://linustechtips.com/topic/713058-gaming-pc-help/#findComment-9096197
Yea okay :) im from Denmark. Thats Maybe why my english is a little rusty
i have heard a little about a new serie from Intel aswell :) is there Any release for thoose yet ?
https://linustechtips.com/topic/713058-gaming-pc-help/#findComment-9096261
Kaby Lake from Intel will just be a Skylake refresh, so the new Intel series is nothing to be excited about. And they will release really soon but in my opinion you should wait for Zen or Skylake-E by Intel if you can't live with an AMD processor in your build. But the Prices for many CPUs by Intel will likely drop when Zen releases so I can only advise you to wait, even if you want to buy Intel.
https://linustechtips.com/topic/713058-gaming-pc-help/#findComment-9096297
