http://www.newegg.ca/Product/Product.aspx?Item=N82E16823816015&cm_re=mechanical_keyboard-_-23-816-015-_-Product
Not too sure if its backlit..
And also, getting mechanical on a budget isnt really going to happen
https://linustechtips.com/topic/713041-keyboard-help/#findComment-9095383
