Math help - Average
Go to solution Solved by Dash Lambda,
Just add of the prices by portion.
To calculate a normal average you add up each value and divide by the number of items, so since you have percentage, you can treat it as 100 items. Instead of dividing the summation by 100, you can simplify it by changing the percentages to their decimal forms, so your calculation is just adding up each price multiplied by its portion.
I need help with a math task.
25% of customers bought product A for 25€.
40% of customers bought product B for 50€.
35% of customers bought product C for 60€.
How do I calculate the average money spend?
Quiet Whirl | CPU: AMD Ryzen 7 3700X Cooler: Noctua NH-D15 Mobo: MSI B450 TOMAHAWK MAX RAM: HyperX Fury RGB 32GB (2x16GB) DDR4 3200 Mhz Graphics card: MSI GeForce 3080 GAMING Z TRIO PSU: Corsair RMx Series RM750x Case: Be quiet! Pure Base 600
Buffed HPHP ProBook 430 G4 | CPU: Intel Core i3-7100U RAM: 4GB DDR4 2133Mhz GPU: Intel HD 620 SSD: Some 128GB M.2 SATA
Retired:
Melting plastic | Lenovo IdeaPad Z580 | CPU: Intel Core i7-3630QM RAM: 8GB DDR3 GPU: nVidia GeForce GTX 640M HDD: Western Digital 1TB
The Roaring Beast | CPU: Intel Core i5 4690 (BCLK @ 104MHz = 4,05GHz) Cooler: Akasa X3 Motherboard: Gigabyte GA-Z97-D3H RAM: Kingston 16GB DDR3 (2x8GB) Graphics card: Gigabyte GTX 970 4GB (Core: +130MHz, Mem: +230MHz) SSHD: Seagate 1TB SSD: Samsung 850 Evo 500GB HHD: WD Red 4TB PSU: Fractal Design Essence 500W Case: Zalman Z11 Plus
https://linustechtips.com/topic/712971-math-help-average/
"Do as I say, not as I do."
-Because you actually care if it makes sense.
https://linustechtips.com/topic/712971-math-help-average/#findComment-9094748
Not sure if this is the best way of doing it, but here is how I'd solve this.
Assume that there are 100 customers.
25 of them paid 25 euro. 25 * 25 = 625
40 of them paid 50. 40 * 50 = 2000
35 of them paid 60. 35 * 60 = 2100
Now let's add them all together.
625 + 2000 + 2100 = 4725
4725 is what they all paid in total, but we want to find the average. To find the average we take the total amount paid, and then divide by the number of people who bought the product. We had 100 people, so we divide by 100.
4725/100 = 47,25
Answer: 47,25 euro
If we want to double check, we can change from 100 customers to 1000. We should get the same result in the end.
250 paid 25. 250*25 = 6250
400 paid 50. 400*50 = 20000
350 paid 60. 350*60 = 21000
6250+20000+21000 = 47250
47250/1000 = 47,25
https://linustechtips.com/topic/712971-math-help-average/#findComment-9094775
