NZXT White S340
I have an X62 Kraken installed on my CPU and I'm looking to install the G10 on my GPU.  I'm a bit OCD on aesthetics, so the only problem is, the only coolers compatible (X51/41 and Corsair) with it aren't braided nicely like the newer model kraken tubes are.  Are there any AiO coolers that have nice braided tubes like the X52/62?  Or do they make heat shrink sleeves you can throw on them but cutting one side and wrapping them around the tube?
I'm going for a clean theme build to try and capture the blue from Nuclear Reactor pools.
https://linustechtips.com/topic/712845-aio-cooler-sleeves/
11 minutes ago, AlgaeEater said:
NZXT White S340
you can buy some colored water cooling tubing and cut it and fit it over.
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/712845-aio-cooler-sleeves/#findComment-9093758
