CPU Load issue
Go to solution Solved by Caphalem,
Have you tried this? It's still weird that this is even happening.
Something doesn't add up. With everything closed, task manager shows 30% usage. But the list only adds up to about 5%.Which makes me thing something is hidden from the list?
Looking at my original post - is it possible i just have an under-powered CPU?
https://linustechtips.com/topic/712772-cpu-load-issue/page/2/#findComment-9099167
10 minutes ago, daimenworrall said:
Could my motherboard be a bottleneck?
I doubt it. Do you have all of the drivers installed? Including the chipset?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/712772-cpu-load-issue/page/2/#findComment-9099213
I will check. I never installed them myself. I usually leave windows update to handle it as it's been fine in the past.
2 hours ago, Caphalem said:
By the sound of things it seems that chrome is being a douche to you. Just throwing this idea out there, have you tried wiping out your chrome installation and installing a new one? Do you use chrome extensions?
This issue persists after a complete reinstall of Windows. I use minimal plugins and the issue seems to be worse when watching YouTube.
It's at its worst when watching twitch. Games are unplayable when watching that.
https://linustechtips.com/topic/712772-cpu-load-issue/page/2/#findComment-9099613
