I have a bit of a problem with my current (and quite annoying) PSU/Power supply and I am looking to replace it as soon as possible.
My current options are:
Cooler master V650s ( http://www.coolermaster.com/powersupply/modular-vs-series/v550s/ )
Cooler master V550s ( http://www.coolermaster.com/powersupply/modular-vs-series/v650s/ )
Corsair Rm650i ( http://www.corsair.com/en/rmi-series-rm650i-650-watt-80-plus-gold-certified-fully-modular-psu )
Corsair Rm550x ( http://www.corsair.com/en/rmx-series-rm550x-550-watt-80-plus-gold-certified-fully-modular-psu-kr )
Unfortunately all of the EVGA and Seasonic supplies in my area are all out of stock.
I am not looking to replace my current PSU with the same model.
I can get the V550s supply before next week and the other supplies a few days after new years.
Any help would be appreciated ^_^
( this is also my first time posting something on the forum :/ )
https://linustechtips.com/topic/712404-power-supply-replacement/
my vote is on the RMi or RMx, guessing the RMx is significantly cheaper than the RMi i guess it'll come down to your budget :P
(also, can someone bring in a heads up on the coolermaster ones? i cant for the life of me remember where in the tiering system they are)
https://linustechtips.com/topic/712404-power-supply-replacement/#findComment-9089926
I wouldn't mind throwing in a few extra bucks for the RMi to be honest :P
https://linustechtips.com/topic/712404-power-supply-replacement/#findComment-9090062
Those PSUs are all good. Get whichever is cheapest. If the V-series is the modular Seasonic X-series based one then it's equivalent on my tiering system with the RMx and RMi.
https://linustechtips.com/topic/712404-power-supply-replacement/#findComment-9090751
