I am looking at getting a motherboard for a Intel Core i7-6700K 4.0GHz Quad-Core Processor to overclock.
I have a budget of 150 for a motherboard. I will be using the computer for graphic designer. DO you guys have any recommendations for motherboards i'm currently looking at these two.
MSI Z170A PC MATE ATX LGA1151 Motherboard
Gigabyte GA-Z170-HD3 ATX LGA1151 Motherboard
Would one be easier to overclock?
https://linustechtips.com/topic/712199-motherboard-for-overclocking/
Gigabyte.
Lower end MSI motherboards like the PC Mate series are known for their merely average quality of power phases.
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
If you have a budget of $150, get the Asus Z170-A or the MSI Z170 Gaming M5.
i5 12600KF | Zotac RTX 4080 Gaming trinity | Team Vulcan 2x16GB DDR4 3600 | ASRock Z690M-ITX/ac | WD Black SN850x 2TB
Cooler Master NR200P v2 | ID Cooling Zoomflow 280 XT | SeaSonic Focus SGX-750 | Thermalright 2x140mm + 2x120mm aRGB
LG C2 OLED 48" 120hz | Epomaker TH80 (Gateron Yellow) | Logitech MX Master 3 | Koss Porta Pro Comm
z170-A is one of the best mobos
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
http://www.ncix.com/detail/asus-z170-a-atx-lga1151-skylake-c4-111462.htm?affiliateid=7474144&promoid=1715
This is the board your recommending right?
2 minutes ago, fujukel said:
Yes. However, you never mentioned you were in Canada. USD is the automatic assumption unless you do so.
Good motherboards for around $150 CAD are-
The Asus Z170-E: http://www.ncix.com/detail/asus-z170-e-atx-lga1151-z170-31-122307.htm?affiliateid=7474144&promoid=2235
The MSI Z170-A PRO: http://www.vuugo.com/computer-hardware/computer-parts/motherboard/MSI-motherboard-Z170-A-PRO.html?tracking=5108053939762
The Gigabyte Z170 MX Gaming 5: http://www.ncix.com/detail/gigabyte-z170-mx-gaming-5-lga-1a-113390.htm?affiliateid=7474144&promoid=1715
Thanks for the recommendations.
