Hello everyone,
I have a front mounted 360mm radiator(EK CoolStream SE 360) as an intake cooling my CPU(i5 6600K) and GPU(GTX 1070). CPU and GPU stays under 50-55C when gaming with 40% fans speeds. Now i have started wondering if the front mounted radiator is a bad thing? Is the hot air that radiator pushes inside the case a problem for other components(like mobo) even when i have 1 140mm fan as an exhaust. Currently the system is running stock speed but i am planning to overclock it abit and add a 240mm or 280mm radiator to the top of the case as an exhaust. Sorry for bad english and thanks for your time. :)
https://linustechtips.com/topic/711911-custom-loop-front-mounted-radiator/
2 minutes ago, Nazaxed said:
Hello everyone,
It probably is bad, but if you have enough airflow it won't be that bad
50c is cold for a GPU
--- Purple Prime ---
i7 8700k + Hyper 212 Evo | MSI Z370 Gaming Pro CarbonG-Skill Trident Z 3000Mhz RGB 16GB | Gigabyte Aorus GTX 1080ti
Crucial MX500 500GB | WD Black 2TB | Corsair RM850i | Fractal Design Define R4LG 27UD68-P | Logitech G502 + G910 | Windows 10 Pro
--- Proteus Server ---
AyyMD Ryzen 5 3600 | Asrock B450m Pro-4 | Crucial Ballistix Sport LT 32 GB (2 x 16 GB) | Sapphire RX570 NITRO+ 8GB
Crucial MX500 1TB + Samsung Spinpoint F4 2TB + Seagate 1TB 2.5" + 5TB iDrive  | Windows 10 Pro (Temporary)
--- Camera Stuff ---
Canon EOS 77D | Canon EF-S 18-55 f/4-5.6 IS STM | Canon EF-S 55-250 f/4-5.6 IS STM | Canon EF 50mm f/1.8 STM
Zoom H5 + XY-5
Phone - Oneplus 6T
CPU: Intel Core i7-5820K | Motherboard: AsRock X99 Extreme4 | Graphics Card: Gigabyte GTX 1080 G1 Gaming | RAM: 16GB G.Skill Ripjaws4 2133MHz | Storage: 1 x Samsung 860 EVO 1TB | 1 x WD Green 2TB | 1 x WD Blue 500GB | PSU: Corsair RM750x | Case: Phanteks Enthoo Pro (White) | Cooling: Arctic Freezer i32
Mice: Logitech G Pro X Superlight (main), Logitech G Pro Wireless, Razer Viper Ultimate, Zowie S1 Divina Blue, Zowie FK1-B Divina Blue, Logitech G Pro (3366 sensor), Glorious Model O, Razer Viper Mini, Logitech G305, Logitech G502, Logitech G402
Hello everyone,
It will warm up the interior but not a problem at all with good airflow through the case, I personally have the same with a 360mm in the front and it does make the interior toasty when on a heavy per-longed load but doesn't hurt anything.
My second rig has horrible airflow so it's a bad thing. But you have more options. So getting all the hot air out and adding another rad could yield better temps, only slightly if you plan on keeping the fans low.
