That would be a reference Radeon RX 480, which is a blower style card. It's not exactly ideal for anything other than SFF builds since an aftermarket variant would likely be cooler and produce less noise.
And as for price, you can virtually get the same card off Newegg for $200 after rebate: http://www.newegg.com/Product/Product.aspx?sdtid=9579572
Alternatively, you could wait until an aftermarket version goes on sale (which is a pretty frequent occurrence).
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
https://linustechtips.com/topic/711605-radeon-rx-480-advice/#findComment-9082863
That's a reference card and VisionTek in particular has horrible packaging. I wouldn't buy it if it was $1. Look for a non reference cooler that isn't Gigabyte.
CPU i7 6700 Cooling Cryorig H7 Motherboard MSI H110i Pro AC RAM Kingston HyperX Fury 16GB DDR4 2133 GPU Pulse RX 5700 XT Case Fractal Design Define Mini C Storage Trascend SSD370S 256GB + WD Black 320GB + Sandisk Ultra II 480GB + WD Blue 1TB PSU EVGA GS 550 Display Nixeus Vue24B FreeSync 144 Hz Monitor (VESA mounted) Keyboard Aorus K3 Mechanical Keyboard Mouse Logitech G402 OS Windows 10 Home 64 bit
https://linustechtips.com/topic/711605-radeon-rx-480-advice/#findComment-9082868
Never buy a reference AMD card for that matter, except for the ones like the fury where they came with that radiator - that's fine.
You can bark like a dog, but that won't make you a dog.
You can act like someone you're not, but that won't change who you are.
Finished Crysis without a discrete GPU,15 FPS average, and a lot of heart
How I plan my builds -
For me I start with the "There's no way I'm not gonna spend $1,000 on a system."
Followed by the "Wow I need to buy the OS for a $100!?"
Then "Let's start with the 'best budget GPU' and 'best budget CPU' that actually fits what I think is my budget."
Realizing my budget is a lot less, I work my way to "I think these new games will run on a cheap ass CPU."
Then end with "The new parts launching next year is probably gonna be better and faster for the same price so I'll just buy next year."
https://linustechtips.com/topic/711605-radeon-rx-480-advice/#findComment-9084178
2 minutes ago, Takoren said:
I would definitely pay that additional cost. The current generation of ASUS Strix cards from both AMD and Nvidia are immensely better than the last generation. Beefy coolers and great build quality from ASUS, as usual.
XFX does have better customer support though, in case something goes wrong.
New Build (The Compromise): CPU - i7 9700K @ 5.1Ghz Mobo - ASRock Z390 Taichi | RAM - 16GB G.SKILL TridentZ RGB 3200CL14 @ 3466 14-14-14-30 1T | GPU - ASUS Strix GTX 1080 TI | Cooler - Corsair h100i Pro | SSDs - 500 GB 960 EVO + 500 GB 850 EVO + 1TB MX300 | Case - Coolermaster H500 | PSUEVGA 850 P2 | Monitor - LG 32GK850G-B 144hz 1440p | OSWindows 10 Pro.
Peripherals - Corsair K70 Lux RGB | Corsair Scimitar RGB | Audio-technica ATH M50X + Antlion Modmic 5 |
CPU/GPU history: Athlon 6000+/HD4850 > i7 2600k/GTX 580, R9 390, R9 Fury > i7 7700K/R9 Fury, 1080TI > Ryzen 1700/1080TI > i7 9700K/1080TI.
Other tech: Surface Pro 4 (i5/128GB), Lenovo Ideapad Y510P w/ Kali, OnePlus 6T (8G/128G), PS4 Slim.
https://linustechtips.com/topic/711605-radeon-rx-480-advice/#findComment-9085658
24 minutes ago, Takoren said:
GTR is the best 480, but not at $30 more. Just get the strix.
https://linustechtips.com/topic/711605-radeon-rx-480-advice/#findComment-9085763
