transfer speed caped
Go to solution Solved by brwainer,
2 hours ago, _BJE_ said:
here is a bit more information. both of the speed test is done in the same time just moved the laptop in different location
This is the cable im currently using
This is the other cable that i have in the living room
They are both cat5e so i have no idea whats wrong
Do you have a line tester? Have you checked what speed the laptop is linking at? This looks to me like in one location your cable is damaged and linking at 100Mb
im having a problem with my network that i have no idea what is going on. the problem is that i have 1Gbps fiber and i know i wont get the full 1Gb but it seems every time i try to sometimes i try to download something i get like 700-800Mbps but some times it caps at 90-100Mbps i just dont know what is going on.
https://linustechtips.com/topic/711202-transfer-speed-caped/
When you get a local download speed that high, your downloads get limited not by you or your ISP, but by how fast the server can upload, and how congested the backbone internet links between you and the server are.
Make sure your router and NIC are capable of gigabit. Many routers hit a CPU limit when you do routing at such high speeds, which doesn't apply to local transfers that are only switched, not routed. Cheaper NICs on computers, such as anything made by Realtek, can't quite make it to a full gigabit. Intel NICs are good, as are a lot of brands that focus on server applications primarily. I'm not sure about Killer NICs.
Do speedtests with dslreports.com/speedtest, which uses multiple connections, not just one. Check with your ISP if there is a specific server on speedtest.net or other sites that they know is capable of showing the full gigabit speed.
Looking to buy GTX690, other multi-GPU cards, or single-slot graphics cards:
https://linustechtips.com/topic/711202-transfer-speed-caped/#findComment-9078756
2 minutes ago, brwainer said:
Thanks but i dont think its on there side that is limiting im using the same software to download and i exceed 60+MBps but now im limmited to 11MBps and it wont go faster then 100Mbps maybe its the router i dont know just want a fix but dont know where to start
https://linustechtips.com/topic/711202-transfer-speed-caped/#findComment-9078778
https://linustechtips.com/topic/711202-transfer-speed-caped/#findComment-9078895
https://linustechtips.com/topic/711202-transfer-speed-caped/#findComment-9079170
First of all, if you have one, try a different cable on the port that seems to be slowed down. If you don't have one, then maybe borrow the one from the other port to test.. if the port is now running faster how it should be, then it was a faulty cable... if it's not working faster, then my guess would be the internal cable has broken somewhere, but depends on what you have between those points, for instance if you have a switch/homeplugs etc then that could be the cause of the problem, test first how I said above and then get back to us with the results please.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/711202-transfer-speed-caped/#findComment-9079786
It seems you are correct. one side of my cable is not connected properly because one of my stupid roommate snapped the little clip off the head leaving it loose. i just tape the end to the port that seems to do the job.
thanks a lot for this and i will defiantly wont steal someones cable.
https://linustechtips.com/topic/711202-transfer-speed-caped/#findComment-9079801
