Which Case Fan?
Solved by WoodenMarker,
14 minutes ago, EricD943 said:Good point... Maybe all I need is an intake then.
Depending on how much you want to spend, some good options include:
Silent12: http://ca.pcpartpicker.com/product/ZpCwrH/gelid-solutions-case-fan-fnsx1210
GP-12: http://ca.pcpartpicker.com/product/DZ8H99/fractal-design-case-fan-fdfandyngp12wt
Magma: http://ca.pcpartpicker.com/product/kFBv6h/enermax-case-fan-ucmaa12a
NF-S12B: http://ca.pcpartpicker.com/product/W4XfrH/noctua-case-fan-nfs12bredux1200
NF-S12A: http://ca.pcpartpicker.com/product/BgvRsY/noctua-case-fan-nfs12apwm
Two front intakes should be plenty.
