How do I improve stock CPU cooler noise issue.
plasticplanet
Every time I boot up my PC, there is a squeaky noise from the fan, and sometimes when opening a software. Also the general fan noise is relatively loud as well. My CPU is i5-6500, I'm usually doing light tasks, the case and GPU fans are idle most time.
If your talking about Case (Cabinet) fans you should replace the screws with rubber mountings on all four sides
and if your cpu fan is creating noise plz replace it
Well, you could try to lube your bearing on your fan, it worked for me on my stock AMD cooler, if not than try replacing the fan with one from another fan. I just replaced mine with a 60mm noctua and what a difference
Stock fans aren't that lout 1200rpm is acceptable. To lower it, go into bios and adjust the fan profile.
Intel Xeon E5 1650 v3 @ 3.5GHz 6C:12T / CM212 Evo / Asus X99 Deluxe / 16GB (4x4GB) DDR4 3000 Trident-Z / Samsung 850 Pro 256GB / Intel 335 240GB / WD Red 2 & 3TB / Antec 850w / RTX 2070 / Win10 Pro x64
HP Envy X360 15: Intel Core i5 8250U @ 1.6GHz 4C:8T / 8GB DDR4 / Intel UHD620 + Nvidia GeForce MX150 4GB / Intel 120GB SSD / Win10 Pro x64
HP Envy x360 BP series Intel 8th gen
AMD ThreadRipper 2!
5820K & 6800K 3-way SLI mobo support list
What are your temps and what speed are your fans running at?
Make sure that the noise is coming from your fan and not elsewhere by stopping the fan with your hand to see if the noise goes away.
You won't get rid of startup noise. Thats part of normal self-testing. You could use low-noise adapters which will also limit general max speed of fan.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
