I had issues with my main HDD drive and I my pc to the store and it was all fixed but a while after it acted up again and I unplugged it and my pc was fine again ( my issue was it kept on opening up document folders and saying my drive wasn't there but it had to be because my windows was on it) so I got windows put on my ssd and kept the hdd unplugged but I decided to test it and it doesn't even show up in the bios but the actual hard drive does work and I can hear it on.
If any one can help I would love it thank you.
https://linustechtips.com/topic/710668-dead-hard-drive/
Can you try opening it with a Linux OS like Mint?
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/710668-dead-hard-drive/#findComment-9072724
Just make a Live USB with Linux Mint.
https://www.linuxmint.com/edition.php?id=226
Pendrive is the USB creator.
https://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/
You'll need to download the ISO and use the Universal USB Installer to create a bootable USB.
https://linustechtips.com/topic/710668-dead-hard-drive/#findComment-9072845
