amoled vs oled difference and which is better?
when will either be available on a monitor?
Amd phenom ii x4 955 Asus crosshair iv formula Kingston hyperx fury 8GB 1600mhz ASUS Radeon R9 280X DirectCU II
Cooler master haf xb evo Antec 750w 500gb wd black BenQ gw2760hs Samsung 850 EVO 250GB 2.5" Solid State Drive
OLED = Organic Light Emitting Diode
AMOLED = Active Matrix Organic Light Emitting Diode
OLED panels are either AMOLED or PMOLED (Passive Matrix OLED)
Essentially, both use the same lighting methods and general technology. The difference is that AMOLED displays uses a TFT to power the LEDs, reducing the voltage required from the CPU/controller, as well as allowing for larger displays due to a storage capacitor actively maintaining a pixel's state. Passive OLED displays require the pixels to hold their state passively, limiting the size of the display.
The vast majority of modern OLED displays are AMOLED, especially if they're decently sized (Passive Matrix OLED is generally limited to around 3" in devices as far as I can find)
We'll probably see AMOLED monitors at CES 2017
EDIT: It seems like some companies have taken to calling their displays AMOLED now. It's kind of causing confusion, or being used as a marketing statistic because people think it's something different. Basically, if it's not on a really small device like an MP3 player, it's most likely going to be AMOLED.
2 minutes ago, Kloaked said:
AMOLEDs are more efficient (on paper) than OLEDs.
The Alienware 13 laptop uses an OLED panel, but it's the only one so far. OLED or AMOLED monitors should be coming soon.
Well, the Alienware 13 is still AMOLED. PMOLED is just way too inefficient for a display of that size.
Refer to the second to last section here.
https://linustechtips.com/main/topic/278610-display-technology-faqmythbuster/
