Nvidia shadowplay won't start, I see the two arrows at the top right, but when I click alt+F9, to enable manual, I get a green dot with the arrows around it, and a red line diagonally through the whole thing, press it again, and it is a green circle with an arrow pointing down, and then it goes back to just the arrows, when I get out of the game, it shows that the directory that I want it to save is empty, and I have the same amount of HDD space as I had before starting the game.
https://linustechtips.com/topic/71028-nvidia-gtx-780-problems/
Ya I would try a different drive or folder.
CPU: 3770K | Motherboard: Asus Maximus V Formula | GPU: GTX 1080Ti SLI | Ram: 16gb Corsair Dominator Platinum 2133 | PSU: Corsair AX1200i | Storage: 2x Samsung 840 pros | Case: Corsair 650D | Cooler:  Corsair H100i with Noctus NF-F12 fans | Monitor: Asus ROG Swift PG278Q
https://linustechtips.com/topic/71028-nvidia-gtx-780-problems/#findComment-973610
Found out why, You can't be in any other folder but the root directory/NVIDIA/SHADOWPLAY that folder is the only one you can use, it would be nice if Nvidia added a folder directory override, because the game directories can't access user folders either, same problem with shadowplay, only it doesn't warn you.
https://linustechtips.com/topic/71028-nvidia-gtx-780-problems/#findComment-973905
