Xbox One controller wireless
By
Guest
in Peripherals
in Peripherals
Solved by Mira Yurizaki,
All wireless Xbox controllers use regular AA batteries for power. If you want rechargeable batteries, you need the plug and play charge kit or equivalent.
The USB port does not charge the batteries unless it's the plug and play charge kit.
5
kasdashd ·
2
6
Ishikudeska ·
Posted in New Builds and Planning2 -
Xxu ·
Posted in Servers, NAS, and Home Lab1
play_circle_filled
Latest From ShortCircuit:
