Best Waterblock for 770?
Go to solution Solved by TheSLSAMG,
OK
oh, sorry… Is there a WB for the ASUS gtx770 DirectCU2?
If not for the reverence model.
Can I use any 770 backlpate with any WB?
http://www.coolingconfigurator.com/step1_complist?gpu_gpus=1078
Hm? Doe not the title say it all?
No. The title doesn't say much.
Like, for example, what model is the card? @Metallus, we need more info.
https://linustechtips.com/topic/70985-best-waterblock-for-770/#findComment-973046
All waterblocks perform similar, just get the ones you think looks best or the cheapest ones.
get the one that looks the best
OK
https://linustechtips.com/topic/70985-best-waterblock-for-770/#findComment-973661
OK
https://linustechtips.com/topic/70985-best-waterblock-for-770/#findComment-973678
