I plan on building a new PC. I kinda don't want to skimp out. I'll follow format;
0. TL;DR -
I want new PC. $2k or less. No compromises though. Here's the link: https://pcpartpicker.com/list/HDLRwV
1. Budget & Location -
I don't really have much of a budget. If you require numbers then < $2300, USD.
2. Aim -
Gaming. I want to be able to run anything on a 3440x1440 monitor with at least 60 frames. I also want to be able to run future games that are likely more computer intensive than current ones, I was considering a 1080 but meh. I am also set on the case, as I wish to make a smaller computer with the power of a full sized one. I also appreciate the aesthetic that the one chosen has. I guess I kind of want a "No Compromises" build. Oh, and I don't plan on overclocking.
3. Monitors -
I will be using 2 monitors, an ultra wide one for games (3440x1440) and a normie one for discord and what not (1920x1080).
4. Peripherals -
I'll need to purchase an OS, but the other peripherals should not be counted in the budget. I have working ones currently and may upgrade in the future.
5. Why are you upgrading? -
Simply put - because I want to. This would be the first PC I will have made, but I'll have guidance from friends who are more experienced with putting them together. My current PC is a mid to low end (~$500) PC that can't really run anything at max graphics on a 1440p monitor.
https://linustechtips.com/topic/709698-pc-build-help/
Your case has a PSU included.  450W is enough for a 6700K + GTX 1070.
You might also want to have a blower style cooler on the GPU to help keep the case air from heating up too much.
Although a 3440x1440 is 1440p, it will require 25% more GPU processing when compared to a 2560x1440 display.
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($324.99 @ Newegg)
CPU Cooler: CRYORIG C7 40.5 CFM CPU Cooler  ($29.88 @ OutletPC)
Motherboard: ASRock Fatal1ty Z170 Gaming-ITX/ac Mini ITX LGA1151 Motherboard  ($159.88 @ OutletPC)
Memory: G.Skill TridentZ Series 16GB (2 x 8GB) DDR4-3200 Memory  ($99.99 @ Newegg)
Storage: Crucial MX300 750GB 2.5" Solid State Drive  ($169.99 @ Jet)
Video Card: Asus GeForce GTX 1070 8GB Video Card  ($399.88 @ OutletPC)
Case: Fractal Design Node 202 HTPC Case  ($78.99 @ SuperBiiz)
Power Supply: Silverstone Strider Gold 450W 80+ Gold Certified Fully-Modular SFX Power Supply  ($87.99 @ SuperBiiz)
Operating System: Microsoft Windows 10 Home OEM 64-bit  ($92.99 @ Amazon)
Case Fan: Fractal Design FD-FAN-SSR3-120-WT 46.5 CFM  120mm Fan  ($4.99 @ NCIX US)
Total: $1454.56
Generated by PCPartPicker 2016-12-20 16:56 EST-0500
https://linustechtips.com/topic/709698-pc-build-help/#findComment-9061389
