Hello all i have been planning on building a new pc for a while now and i have now started saving. I was looking at a pc which cost around £500 all new parts but then i realized i didn't need all that performance. I then looked at a dell optiplex 960 with an i7 2600 but then realized it would cause real problems for me as a first time gaming pc owner with the prebuilt upgrade restrictions. I am now looking for a pc priced at around £350. Below would be best but any options will be much appreciated. I live in England and the parts can be used.
Cheers!
https://linustechtips.com/topic/709649-first-pc/
https://linustechtips.com/topic/709649-first-pc/#findComment-9060904
2 minutes ago, 1Gigabyte said:
Hello, I will use it for general web browsing and gaming. Fan noise is more a luxury for me its fine if it's loud but the quieter the better. And i would like to keep it for maybe a year or two when i will upgrade it, Thanks!
please quote people using the quote button when you respond, they will get notified that way and be able to respond.
https://linustechtips.com/topic/709649-first-pc/#findComment-9060907
1 minute ago, Sirmat said:
you can upgrade it with a GTX 1050 ti or a Rx 470 4gb graphic card and 8gb of ram
https://linustechtips.com/topic/709649-first-pc/#findComment-9060910
PCPartPicker part list: https://uk.pcpartpicker.com/list/kWqzXH
Price breakdown by merchant: https://uk.pcpartpicker.com/list/kWqzXH/by_merchant/
CPU: AMD A10-7890K 4.1GHz Quad-Core Processor  (£132.15 @ CCL Computers)
Motherboard: Gigabyte GA-F2A68HM-HD2 Micro ATX FM2+ Motherboard  (£37.97 @ Amazon UK)
Memory: Kingston 8GB (1 x 8GB) DDR3-1600 Memory  (£41.19 @ Amazon UK)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  (£43.99 @ Amazon UK)
Case: Fractal Design Core 2300 ATX Mid Tower Case  (£41.49 @ Ebuyer)
Power Supply: Corsair CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  (£51.60 @ CCL Computers)
Total: £348.39
Generated by PCPartPicker 2016-12-20 20:27 GMT+0000
Remember to quote me (or someone else), otherwise we won't going to recieve your answers...
PC Specs                   PCPartpicker full performance builds (from350$-1250$)
https://linustechtips.com/topic/709649-first-pc/#findComment-9060933
