I just found out that my water cooler was leaking. It was leaking from a small hole somewhere in it and I can't find it. I got lucky when I caught it. I was dripping into the backplate on my graphics card but it may have been doing that for about two weeks when I noticed that there was some water missing from the res. So I assumed it was pushing around air bubbles. I am just so glad that my pc didn't get shorted. So I guess my question is, is there any way to plug the hole up and use the radiator still?
https://linustechtips.com/topic/709292-issue-with-radiator/
How long have you had it?
AMD FX 6300 @ 4.6 Ghz CRYORIG H7 Asus M5A97 PLUS | HyperX Fury 8 GB DDR3 | PNY CS1311 120gb SSD WD Blue 1TB 7200 RPM EVGA GeForce GTX 950 Superclocked NZXT Source 210 Black EVGA 500B Logitech G Pro HP K3500 Wireless Keyboard |
https://linustechtips.com/topic/709292-issue-with-radiator/#findComment-9056536
I assume it's a custom loop, the only way would be reliably fix it is to solder the hole in the rad and pressure test it to I believe most are around 15-20 PSI.
https://linustechtips.com/topic/709292-issue-with-radiator/#findComment-9056846
Yeah it seems the leek is Deep in the rad so I'm screwed
https://linustechtips.com/topic/709292-issue-with-radiator/#findComment-9062205
Yeah that may be a problem if it's not accessible, you may want to try and contact the manufacture to see if they can do anything or if it's still under warranty.
https://linustechtips.com/topic/709292-issue-with-radiator/#findComment-9062215
