Need serious help with W8.1
I don't understand how this will change the PCs password though?! It looks like you are instructing me how to change my microsoft account password (or am I mistaken?)
It will change your PC password. When you installed Windows 8.1, you were asked to enter a microsoft account you want to TIE with your system account.
The idea behind this are:
-> All Microsoft Modern UI applications that requires logging in (Mail, Calandar, People, XBox Music, Store, etc.), will not ask you to login.
-> If you tie another system with the same microsoft account, you can have your Windows settings, including wireless passwords, in sync between them.
-> SkyDrive will sync your files (inside the SKyDirve folder) between systems using the same Microsoft account.
-> Installed Modern UI apps, will be in sync between your systems.
http://windows.microsoft.com/en-us/windows-8/microsoft-account-tutorial
