1 minute ago, KeFy said:
going to be using this for gaming
https://pcpartpicker.com/list/
RX 480 can def handle much larger monitor than that, but it's personal preference, also the cooler although is good enough will not be able to support big OC if thats what you're gonna get into.
https://linustechtips.com/topic/707685-thoughts-on-build/#findComment-9039785
5 minutes ago, KeFy said:
yes i do have a dusin ssds laying around forogot to mention that
https://pcpartpicker.com/list/jbM6NN
You could get a cheaper 1080 and splurge a bit more on the CPU cooler. I wasn't sure if there was a reason you wanted to go for that specific 1080, so I just left it alone.
BOINC Setup:
i5 7200U @ Stock
Core2Duo T6600 @ Stock
i3 2330M @ Stock
i5 3210M @ Stock
https://linustechtips.com/topic/707685-thoughts-on-build/#findComment-9039846
