So, I went to a MicroCenter today, and they had a display to try on the Corsair Void. I did, and while it was really comfortable, it was pretty big (well, only the earcups, but whatever). Does anyone know of a good headset from a reputable brand, have wireless capabilities (Bluetooth or dongles, either is fine), and have LED lighting, preferably RGB? My budget is under 100 USD, thanks!
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/706908-headset-smaller-than-a-void/
The Logitech g933 is about the equivalent, the earcups are not as massive (though they are chunky), it's wireless and has RGB lighting, and at that price point.
I bought one the other day, didn't personally like it but that was because it didn't fit me, was too small.
GTX 3080 Ti ROG | Ryzen 5600X | MSI Tomahawk B550 | 32GB 3600MHz | Corsair 850e | HAF X | WD SN850X | Asus MG287Q 1440p 144Hz
What do you  mean by "chunky?" I want something that has "thin" earcups, if that makes any sense.
SPECS:
Oh okay. The earcups are extremely thick, the headset is pretty bulky. When you said big earcups thought you meant in terms of area (i.e length/width) rather than depth. The Voids look massive.
