Hello,
I am currently doing a  PC mod and I went out and bought a momentary push button.
but,
this switch has 2 NO, NC, C, and 1 set of + - pins.
which do i solder to the cables that connect to the motherboard.
all I know is that the +- pins power the green light on the button.
Thanks!
https://linustechtips.com/topic/706898-custom-pc-power-switch/
Sounds like a borked switch.
The switch terminals are supposed to be open at all times while depressed.
D.VA coming soon™ xoxo
Gulliver Nokia Lumia 1320
Werkfern Nokia Lumia 520
Hydromancer Acer Liquid Z220
https://linustechtips.com/topic/706898-custom-pc-power-switch/#findComment-9032727
Does the switch have an led inside? That's what the +/- pins are probably for. As for the NO NC and C contacts, I'd try to  connect the NO and C. Check continutiy with a multimeter to see which contacts pass current when the switch is depressed, then use those contacts.
https://linustechtips.com/topic/706898-custom-pc-power-switch/#findComment-9033653
