Build for a friend
Go to solution Solved by MIXFUSED,
2 hours ago, nerb said:
Yeah it's non k. I'm just scared cause the case only comes with one fan and if I wanted to add another I would have to go find a fan controller or splitter because the MOBO only has two fan headers
It will be fine, its non-k so stock cooler would do fine. It'll be fine.
Hey peoples, I had my friend order parts for his first build and for some reason I told him to buy a Noctua NH-L9i SSO2 CPU cooler.
The reason why I am concerned with this purchase is because it's going to be built in a Corsair Carbide SPEC-M2 mATX case with an i5 6500 CPU...
Seeing that he has already received all the parts, will this ITX designed cooler be sufficient enough for his config?
Corsair 350d, Intel 3570k @ 4.2 ghz, H100i, Caviar blue 500gb, Caviar Blue 1TB, Samsung EVO 850 Pro 256GB, EVGA GeForce GTX 1060 ACX 3.0, Corsair Vengeance 8gb,AX760i
 2013 Macbook Pro 15-inch
https://linustechtips.com/topic/706861-build-for-a-friend/
It's a non k i5, it will do fine even with the stock cooler.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/706861-build-for-a-friend/#findComment-9029794
Yes.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/706861-build-for-a-friend/#findComment-9029797
https://linustechtips.com/topic/706861-build-for-a-friend/#findComment-9029808
https://linustechtips.com/topic/706861-build-for-a-friend/#findComment-9029873
Ok great thanks, I just needed a little reassurance haha
https://linustechtips.com/topic/706861-build-for-a-friend/#findComment-9029876
