3 minutes ago, Skittleslovers02 said:
Hi just got a new case (Corsair 250D) and was wondering what fans i should use?? (First Time Builder)
The fan spots open for me are:
1x 200mm
1x 120mm
2x 80mm (Should i use these?)
And a fan hub...Already have a 120mm fan from my CPU cooler for the rad.
High budget..Noctua, be quiet,
Med budget....Fractal design Venture
Low...Corsiar AF, SP
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
https://linustechtips.com/topic/706714-case-fan-help/#findComment-9028158
https://linustechtips.com/topic/706714-case-fan-help/#findComment-9028170
1x 200mm
1x 120mm
What are your specs? You probably don't need Noctua fans tbh. But if you want to keep your build silent then they'll do you well.
https://linustechtips.com/topic/706714-case-fan-help/#findComment-9028183
