i want to water cool my pc, not because my pc is struggling head wise (well a founders 1080 is hot) or because i just need the extra 5% i will get from overclocking
i want a custom loop because i am a pc enthusiast and want to have a sick water loop like lost of the people
i have a nzxt noctis 450. could i fit something like this in my case?
And i assume i could add a GPU block in the future?
https://www.ekwb.com/shop/ek-kit-p360
https://linustechtips.com/topic/706100-help-your-fellow-beginner/
Hear me out - EKWB offers a custom-loop grade AIO with support for adding a GPU block pre-filled in the future.
The kits are pretty good value too, so you can go with that. You can add a GPU block if I remember correctly.
idk
cpu or gpu?
if cpu, whats limiting you? the cpu itself (bad overclocker) or the temps? temps -> better cooler (preferablly air, dh15 is nice)
gpu? well, im bad at gpus so.. :P
Ryzen 5 3600 stock | 2x16GB C13 3200MHz (AFR) | GTX 760 (Sold the VII)| ASUS Prime X570-P | 6TB WD Gold (128MB Cache, 2017)
Samsung 850 EVO 240 GB
138 is a good number.
1 minute ago, themctipers said:
cpu or gpu?
cpu is just a terrible overclocker, im doing it for the gpu, and the experence of constructing a custom loop
If you wanted to add a GPU later all you'd be missing is obviously the GPU block in addition to the two fittings. I'd highly recommend doing your research on block availability before purchasing a GPU though as non reference cards can be difficult to find blocks for.
Edit: Noticed you have a Founders 1080 so it shouldn't be an issue at all.
CPU - Ryzen Threadripper 2950X | Motherboard - X399 GAMING PRO CARBON AC | RAM - G.Skill Trident Z RGB 4x8GB DDR4-3200 14-13-13-21 | GPU - Aorus GTX 1080 Ti Waterforce WB Xtreme Edition | Case - Inwin 909 (Silver) | Storage - Samsung 950 Pro 500GB, Samsung 970 Evo 500GB, Samsung 840 Evo 500GB, HGST DeskStar 6TB, WD Black 2TB | PSU - Corsair AX1600i | Display - DELL ULTRASHARP U3415W |
You can get that and order a prefilled gpu block that will simply plug into the CPU loop. Can't say forsure if it will fit in the case. Still on my phone at work.
half of the reason i want this is the experience of building a custom watercooling loop
Yell this kit will do just that.
This kit is basicly EK taking their off the shelf parts and throwing them in a box taking out any guess work.  Its got a fantastic CPU block, pump, radiator and fans all in one package.  The pump it comes with could easily handle expansion (you adding radiator(s) or gpu blocks).
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
