5 minutes ago, Kala said:
so gtx 1070 amp extreme zotac videocard is on the way and im wondering will it fit into
NZXT Phantom 410 Series CA-PH410-B1 case ty in forward
It will be a tight squeeze, I would suggest the regular amp edition over the extreme. The extreme weighs too much and will cause sag on your motherboard, which can break the pci-e slot.
Edit: oh, I didn't notice that you had said it is already on the way. You may want to get a holdup bar for that gpu then.
8086k Winner BABY!!
Main rig
CPU: R7 5800x3d (-25 all core CO 102 bclk)
Board: Gigabyte B550 AD UC
Cooler: Corsair H150i AIO
Ram: 32gb HP V10 RGB 3200 C14 (3733 C14) tuned subs
GPU: EVGA XC3 RTX 3080 (+120 core +950 mem 90% PL)
Case: Thermaltake H570 TG Snow Edition
PSU: Fractal ION Plus 760w Platinum
SSD: 1tb Teamgroup MP34  2tb Mushkin Pilot-E
Monitors: 32" Samsung Odyssey G7 (1440p 240hz), Some FHD Acer 24" VA
GFs System
CPU: E5 1660v3 (4.3ghz 1.2v)
Mobo: Gigabyte x99 UD3P
Cooler: Corsair H100i AIO
Ram: 32gb Crucial Ballistix 3600 C16 (3000 C14)
GPU: EVGA RTX 2060 Super
Case: Phanteks P400A Mesh
PSU: Seasonic Focus Plus Gold 650w
SSD: Kingston NV1 2tb
Monitors: 27" Viotek GFT27DB (1440p 144hz), Some 24" BENQ 1080p IPS
You will need to remove the top drive cage to fit it. The Phantom 410 supports 305mm graphics cards with the drive bay installed, but the card is 325mm long. With the drive cage removed, it increases to 420mm.
9.06" (230mm) With Drive Cages
12.01" (305mm) Without Drive Cages
My Main PC:
CPUi5 3570k CPU Cooler: Cooler Master Hyper T4 Motherboard: Asus p8z77-v pro  RAM: Crucial Balistic 2x4gb  GPU: Two PNY GTX 680's in SLI Case: Some rando Antec one  PSU: Thermaltake 1000w  Display: HP Elite Display 321i 23''  Storage: Samsung 840 Evo 128gb, Seagate Barracuda 1tb
 Yes
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
6 minutes ago, mpsparrow said:
What is your build? pcpartpicker will tell you if it will fit or not.
https://pcpartpicker.com/list/Zy7XVY thats the thing it would be easy right im buiying it locally since everything is ordered theres no phantom 410 on pcpart
removing the cage wont be a problem now i can rest ty
305mm is the clearance without the fan installed on the front of the drive cages. 230mm is with the fan installed at full pivot. With the cages removed, it goes up to 420mm.
1 minute ago, Kala said:
ty for simple answer
You might have to leave a couple hard drive bays unused to fit it. But it will fit if you do that.
Computer Specs:
so if i remove drive bays at bottom 365mm should fit well and there shouldnt be any problems ty for fast answers
You'll want to remove the top section of the drive bays. They will just slide out. Then it will easily fit. Removing the bottom bays won't offer any extra clearance for GPUs as the PCIe slots all line up with the top bays.
With the top bays removed, you still have 3 drive bays left, as well as the 5.25" bays at the top.
21 minutes ago, huilun02 said:
Did you just buy that case? Should have gotten an S340 instead. Wayy more modern.
Looks? Thats usually the reason people buy a case, and wanting a power button.
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
2 hours ago, Kala said:
those seem pretty small like rly
got it right off of pcpartpicker
My Main PC:
