2 minutes ago, echy said:
Is there a case where there's easy plugin for external hard drives like onto of the case
Something like an external 3.5" for HDD? Like where you can insert a WD blue from the outside? Yeah there is
has a backport panels usb plugins
Like a back I/O from the motherboard?? Or a USB card to have more USB ports in the back?
3 minutes ago, echy said:
has something to clean out the dust like a dust catcher?
Most cases has removable dust filters
https://linustechtips.com/topic/705606-case-question/#findComment-9015155
yes, do you have a name for one?
7 minutes ago, echy said:
if the motherboard has one then yes, idk whats a usb card, but my goal is to get a usb adaptor to the back of my pc so i can get multiple ports, do pcs already have a usb port in the back because then i can just use that instead.
can you name one? so i can check it out
https://linustechtips.com/topic/705606-case-question/#findComment-9015176
All motherboards always have USB ports on the back. it's the standard these days!
If you want stylish cases, look into stuff from phanteks or IN WIN. i dunno about any cases with hotswap bays for external HDDs though. i'd have to look for some.
https://linustechtips.com/topic/705606-case-question/#findComment-9015189
Here pcpp allow you to list case with external 3.5 bay
http://pcpartpicker.com/products/case/#H=1,8
You can add a usb card, take a look at my review of one so you can have more usb ports if you ran out of it
Motherboard should come with some, look at pictures of mobo you buy for reference
https://linustechtips.com/topic/705606-case-question/#findComment-9015197
