As the title says, I'm looking for a case. I want one that is able to fit a Noctua NH-D15 82.5 CFM CPU Cooler
and also have a power supply basement with a window on the side. If possible maybe 4 usb ports in the front with a
potential for a blu-ray drive as well.
EDIT: I forgot to mention that I want a Mid-Tower
Sorry for the blunder
https://linustechtips.com/topic/705480-choosing-a-case/
Corsair 400C should fit the job quite nicely, only thing is your disc drive would have to be an external drive opposed to an internal drive
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
https://linustechtips.com/topic/705480-choosing-a-case/#findComment-9013884
https://pcpartpicker.com/product/9XL7YJ/fractal-design-case-fdcadefr5bkw
https://pcpartpicker.com/product/jrVBD3/phanteks-case-phes515pbk
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/705480-choosing-a-case/#findComment-9013885
I have the Phanteks Enthoo Pro, it fits all your parameters, it can hold big cpu coolers, has PSU basement, side window, and 2 usb 3.0 and 2 usb 2.0 ports on the front (plus audio and mic jack), 3 5.25" bays, and a side window. All for 89.00 USD :)
Cheers.
Newegg (US): http://www.newegg.com/Product/Product.aspx?Item=N82E16811854003&cm_re=Phanteks_Enthoo_Pro-_-11-854-003-_-Product
Linus' review:
https://linustechtips.com/topic/705480-choosing-a-case/#findComment-9013917
