Good monitor for a GTX 1070?
Okjoek
My youngest brother uses a GTX 1070 and he's still using a really old monitor from HP. 1680x1050
Atleast 1080p.
Budget is ~ 150 dollars.
Whats the budget?
There should be some 1440p 60hz panels. 1080p is just too low and your card would be wasted at 1080p 60Hz.
Connection200mbps / 12mbps 5Ghz wifi
My baby: CPU - i7-4790, MB - Z97-A, RAM - Corsair Veng. LP 16gb, GPU - MSI GTX 1060, PSU - CXM 600, Storage - Evo 840 120gb, MX100 256gb, WD Blue 1TB, Cooler - Hyper Evo 212, Case - Corsair Carbide 200R, Monitor - Benq  XL2430T 144Hz, Mouse - FinalMouse, Keyboard -K70 RGB, OS - Win 10, Audio - DT990 Pro, Phone - iPhone SE
13 minutes ago, ImperialSteele said:
I have two of these for my 1070, work nicely. (The sale has been on since I first looked at them, so it shouldn't go anywhere)
http://www.newegg.com/Product/Product.aspx?Item=N82E16824014378
27" 1080p NO ! PPI is crap. 24" is max you should go with for 1080p
For movies and video wathcing from your bed/couch fine, it makes sense but for sitting 2 feet away from it its not worth the money. Size doesnt matter, Resolution does.
A 1070 would be wasted on anything less than 1440p. I have a 1070 G1 with a 27" 1440p ( ASUS MG279Q ) and its perfect,
Ryzen 7 5800X3D, Corsair H105, Gigabyte x570 Aorus Elite, Corsair Vengeance 32GB 3600MHz, EVGA RTX 3070Ti FTW3, Samsung 850 Pro / WD SN850 / OCZ Trion 150
ASUS MG279Q, Corsair Carbide 275R
13 minutes ago, Mello said:
I plan on getting this myself.
LG 32MA68HY-P 32-Inch IPS Monitor
1080p
IPS panel
32 inch
x2 USB 2.0
$199
32" ????? 1080p :D:D:D descrption talks about "clarity" worst markerting ever. Absolute nonsense..
1 minute ago, Thony said:
32" ????? 1080p :D:D:D worst mazrkerting ever. Absolute nonsense..
I don't see your sense.
Go ahead and calculate PPI (pixel per inch) and look at standard sizes for 1080p, 1440p and 4K screens.
Look at it this way. You take a photo with your phone, u go and enlarge/resize it to double the size. You lose clarity of the image because you create larger photo with same amount of pixels...
At 24" u have to get really clsoe to see individual pixels on the screen, at 32" you see them from where u sit... U want to stare at pixel blocks ? I dont think so.
26 minutes ago, Thony said:
-snip-
NO, what if i wanty a steady framerate, no matter the explosions, projectiles, air/water effect particles and doll spawning, etc!?
:D. You calling my GTX 770 outdated btw? It cant even handle 1080p anymore :L
Wont have a new gpu tough for the next 100 years atleast i suppose now :U...
FMU
Groomlake Authority
I never talked to you ever so stop putting words in my mouth ;)
i'm not gonna glue my face to the monitor, so i'll probably be fine.
and I already have a 22 inch 1080p monitor and I don't like it.
Not sure you realize the 10" difference but be my guest , your setup not mine.
I do realize the 10" difference, that's why I'm getting it xD
What? even my gtx 660 can handle 1080p.
Personal build >  New-ish AMD main gaming setup
   PLEASE QUOTE OR @ ME FOR A RESPONSE xD
1 hour ago, Megah3rtz said:
-snip-
Try playing Crysis 3 Max settings 60 fps pls...
Or should i say 30 x-x xD. Even the original Crysis 1 can dip below that in some scenes (Well i suppose its not properly optimized for such cards tough, uh?)!
Games are becoming too demanding in VRAM, Bus speeds, memory bandwidth, clock speeds and the marvelous Cuda architecture theses days -.-, and even a mildly high overclock aint gonna help this aging 2GB 770.
Groomlake Authority
