Hey everyone,
A couple of days ago i posted a topic about my future build. I got some advice and changed the cpu cooler.
Now i'm curious what other builds are possible for the same price.
my budget is around €900,-, located in the netherlands, so use the german pcpartpicker. don't need any peripherals/ os or GPU. i'm planning on mainly gaming and programming for school.
I'll take my GPU from the pc i use now. it is an 750ti. planning to buy a 1070 later in 2017.
Thanks for showing me some builds and maybe chage up my whole pc idea.
theme is black and red, but open to other theme's as well.
TL;DR. make a pc around €900,-, german pcpartpicker. no GPU, OS or peripherals
~i5-7600k @5GHz ~Be Quiet! Dark rock 3 ~MSI GTX 1070 Gaming X 8G ~Gigabyte GA-Z270-gaming K3 ~Corsair Vengeance Red led ~NZXT S340 Elite
https://linustechtips.com/topic/704727-better-builds-same-price/
11 minutes ago, Glennieboyyy007 said:
Hey everyone,
For that price, not including a GPU...  I'd get a ASUS Z270-A (whenever it comes available) and then a Core i5-7600k with a bunch of storage, or a Core i7-7700k with a modest amount of storage.
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/704727-better-builds-same-price/#findComment-9006597
38 minutes ago, Jorgen297 said:
You're overpaying for the motherboard, RAM, PSU and especially the case. These are components which doesn't really affect performance much. I would wait 1 month for Kaby Lake.
what kind of Ram, PSU and case are better/cheaper?
https://linustechtips.com/topic/704727-better-builds-same-price/#findComment-9006673
