Hot CPU with Cold AIO?
Solved by Cody_53027,
After I posted this, it got ALOT worse. Fans were @ 2000rpm+, water temp got to 60c-ish, and package temps were upper 90s-100c @ stock clocks. I came to the conclusion either my waterblock lifted off heatspreader, thermal paste was inefficient or I had a kink in my tubing. Turns out I might have had a little of all 3. Reapplied thermal paste, tightened hold-down screws, and adjusted tubes now overclocked to 4.6 @ 35c, package @ max of 80 with RPMs around 1300. FYI, working in a NCASE M1.
