Im going to upgraded my 1 TB HDD to a Samsung 1 TB SSD. The programs I have on it are Google chrome, steam and games, CCleaner, DS4 Controller App, Geforce Experience, Razer Synapse, Skype, Origin, and Microsoft Student with Word, Powerpoint, and Excel. SInce I am upgrading my HDD to an SSD should I uninstall of the programs from the HDD, install the SSD and redownload or is there any way for me to transfer the programs? I already have a separate SSD with my OS and spotify on it. Its my boot drive.
https://linustechtips.com/topic/704459-ssd-upgrade-transfer-help/
The samsung SSD would have came with cloning software. Alternatively, you can find cloning software online, though i have used any of it.
******If you paste in text into your post, please click the "remove formatting" button for night theme users.******
CPU- Intel 6700k OC to 4.69 Ghz GPU- NVidia Geforce GTX 970 (MSI) RAM- 16gb DDR4 2400 SSD-2x500gb samsung 850 EVO(SATA) Raid 0 HDD- 2tb Seagate Case- H440 Red w/ custom lighting Motherboard - MSI Z170 Gaming A OS- Windows 10 Mouse- Razer Naga Epic Chroma, Final Mouse 2016 turney proKeyboard- Corsair k70 Cherry MX brown
https://www.paragon-software.com/home/hdm-personal/
That's what I use, and it works great! It is a tad bit on the expensive side though.
widget.png?style=banner2
PC: 9800X3D, 96GB Trident Z5 6200 CL28, 5090 FE, 3.84TB CM7
NAS: Xeon W-2195, 256GB ECC, 180TB Storage, 1660 Ti, TrueNAS Scale
Thanks! Another Question. When I configured my drives when i first built my pc I set my SSD as the C drive and my HDD as my S drive. When I uninstall the HDD and install the SSD, will i have to configure the SSD so my PC recognizes it? WIll I be able to rename the SSD as storage again?
If you clone the HDD, you only need to configure the boot priority (if it's on the SATA 0 port, no need to worry). Yes, you probably can rename the SSD as storage
