Raid 1 setup HELP
Solved by davidna2002,
not sure if someone answered the question that you would lose all data on the original disk when you went to configure the RAID so you'd need to move the data off. if the info to save is really valuable you'd NOT want to use WD Blue but WD Black (preferred) or WD Red. However if the data is really precious use cloud storage like Google Drive, iCloud, Sky Drive etc. prices are very cheap and may be free if you don't have quite 1TB worth of data. And lastly after being in IT server and storage roles for a long time RAID is still not 100% safe especially if the RAID controller dies which can nuke both drives.
