Dedicated attack against my PC Network?
Solved by vorticalbox,
1 minute ago, Flashie said:If thats indeed whats happening in this case how do i stop him from scanning my IP's ports that its appearing in the router logs, or how do i scan his IP's ports so that it does :P?
To be honest it could easily be someone just scanning massive IP ranges to see what they can find.
I used to do it to find web servers. You put in a range and scan port 80,8080 found so weird blogs that way lol
